#3213: v.net.iso - Segmentation fault
Reporter: sebastic | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Vector | Version: svn-releasebranch72
Keywords: | CPU: Unspecified
Platform: Linux |
As reported by Eduardo Corbelle Rico in [https://bugs.debian.org/845429
Debian Bug #845429]:
> It happened to me that the use of v.net.iso command results in a
> segmentation fault. I could replicate the error in two different
> machines, with my own data and with both examples shown in the online
> manual ( https://grass.osgeo.org/grass70/manuals/v.net.iso.html )
> using the Spearfish dataset for GRASS 7.
> After consultation in the GRASS-user list, it seems that this is
> specific of the pre-compiled package (installed via apt-get), as the
> error does not appear when GRASS 7.0 is compiled from source in the
> same machine.
The related discussion on grass-user is at:
https://lists.osgeo.org/pipermail/grass-user/2016-November/075606.html
Running the commands from the example gets the following backtrace from
gdb:
(gdb) run
Starting program: /usr/lib/grass72/bin/v.net.iso input=myroads_net
output=myroads_net_iso center_cats=1-100000 costs=1000,2000,5000
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Building graph...
Registering arcs...
Program received signal SIGSEGV, Segmentation fault.
tavl_probe (tree=tree@entry=0x6427d0, item=item@entry=0x84cd30) at
tavl.c:146
146 tavl.c: No such file or directory.
(gdb) bt
#0 tavl_probe (tree=tree@entry=0x6427d0, item=item@entry=0x84cd30) at
tavl.c:146
#1 0x00007ffff6c55737 in dglTreeNodeAdd (pavl=0x6427d0,
nKey=nKey@entry=1) at tree.c:73
#2 0x00007ffff6c4aa0c in dgl_add_edge_V1 (pgraph=0x7fffffffd3a8,
nHead=<optimized out>, nTail=<optimized out>, nCost=1231014, nEdge=1,
pvHeadAttr=pvHeadAttr@entry=0x0, pvTailAttr=0x0, pvEdgeAttr=0x0, nFlags=0)
at edgemgmt-template.c:59
#3 0x00007ffff6c48a62 in dglAddEdge (pGraph=pGraph@entry=0x7fffffffd3a8,
nHead=<optimized out>, nTail=<optimized out>, nCost=<optimized out>,
nEdge=nEdge@entry=1) at graph.c:624
#4 0x00007ffff7ba1769 in Vect_net_build_graph
(Map=Map@entry=0x7fffffffcfd0, ltype=ltype@entry=6, afield=afield@entry=1,
nfield=nfield@entry=2, afcol=0x0, abcol=0x0, ncol=0x0, geo=0, version=1)
at net_build.c:918
#5 0x0000000000402aee in main (argc=<optimized out>, argv=<optimized
out>) at main.c:224
The issue can be reproduced with the GRASS 7.0.5 and 7.2.0-RC2 packages in
Debian. In what way the custom compile differs from the Debian package
build is not clear yet.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3213>
