[GRASS-dev] [GRASS GIS] #3223: r.info displays wrong timestamp after t.rast.series with a where clause
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Default | Version: svn-trunk
Keywords: r.info | CPU: Unspecified
Platform: Linux |
If I run t.rast.series using a where clause, r.info of the resulting map
shows the timestamp of the whole time series and not that of the temporal
selection performed with where.
The selection of maps is fine given that I get the right list of maps when
using the same where clause in t.rast.list, and the values of resulting
maps using the whole time series or just a selection, differ as expected.
Here is a reproducible example:
r.mapcalc expression="prec_1 = 100" --o
r.mapcalc expression="prec_2 = 200" --o
r.mapcalc expression="prec_3 = 300" --o
r.mapcalc expression="prec_4 = 400" --o
r.mapcalc expression="prec_5 = 500" --o
r.mapcalc expression="prec_6 = 600" --o
t.create type=strds temporaltype=absolute \
     output=precip_abs title="Example" \
     descr="Example" --o
t.register -i type=raster input=precip_abs \
     maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
     start="2001-01-01" increment="1 months" --o
t.rast.series input=precip_abs output=precip_abs_average
r.info precip_abs_average
t.rast.series input=precip_abs output=precip_abs_average_3months \
where="start_time >= '2001-04-01'"
r.info precip_abs_average_3months
t.rast.list precip_abs where="start_time >= '2001-04-01'"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3223&gt;
  Priority: normal | Milestone: 7.4.1
Resolution: | Keywords: r.info
       CPU: Unspecified | Platform: Linux
Comment (by huhabla):
Fixed in grass trunk reveision r72479. Please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3223#comment:2&gt;
Comment (by neteler):
Replying to [comment:2 huhabla]:
> Fixed in grass trunk revision r72479. Please test.
Quick question: should test_t.sereis_bug_3223.sh be in trunk and be
backported?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3223#comment:3&gt;
Comment (by veroandreo):
After testing, I backported to release branch 74 in r72493 and to release
branch 72 in r72499 (this last one without test_t.sereis_bug_3223.sh)
Thanks!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3223#comment:4&gt;
Please close the ticket if issue is solved.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3223#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.info
Changes (by veroandreo):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:5 neteler]:
I had left it open because there's an open question (see comment 3).
However, since the issue is fixed, I close it now. Re-open if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3223#comment:6&gt;
