GDAL
December 21, 2016, 6:12pm
1
#3230: lib/raster/gdal.c – missing libgdal.20.dylib in the GDAL library names list
Reporter: vince | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: LibRaster | Version: svn-releasebranch72
Keywords: | CPU: Unspecified
Platform: MacOSX |
static void load_library(void)
static const char *const candidates = {
# ifdef __unix__
"libgdal.so.20",
"libgdal.so.1",
"libgdal.1.1.so",
"gdal.1.0.so",
"gdal.so.1.0",
"libgdal.so",
"libgdal1.6.0.so",
"libgdal1.7.0.so",
# endif
Humm… where is “libgdal.20.dylib” for poor MacOS X users?
Shame on you!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
December 21, 2016, 7:09pm
2
Priority: normal | Milestone: 7.0.6
Resolution: | Keywords: macosx
CPU: Unspecified | Platform: MacOSX
Changes (by martinl):
* keywords: => macosx
* milestone: => 7.0.6
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:1> ;
GDAL
December 21, 2016, 7:15pm
3
Comment (by martinl):
Based on (1) correct identification is
__APPLE__ && __MACH__
or
__APPLE__
is enough?
(1) https://sourceforge.net/p/predef/wiki/OperatingSystems/
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:2> ;
GDAL
December 21, 2016, 7:44pm
4
Comment (by vince):
Will try and let you know. Thanks for your reactivity
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:3> ;
GDAL
December 21, 2016, 7:49pm
5
Comment (by vince):
test.c:
#include <stdio.h>
int main (int argc, char * argv ) {
#ifdef __APPLE__
printf ("Apple!\n");
#else
print ("Something else. Yuck :P\n");
#endif
Air > clang -o test test.c
Air > ./test
Apple!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:4> ;
GDAL
December 21, 2016, 7:50pm
6
Replying to [comment:3 vince]:
really for my reactivity? No, thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:5> ;
GDAL
December 21, 2016, 7:56pm
7
Comment (by vince):
Woops, sorry. I didn’t mean you were sour.
Sometimes when I’m tuckered some French words manage to seep in.
I’m still stuck though. Adding the dylib name won’t suffice, as MacOS X
doesn’t define LD_LIBRARY_PATH, so the whole path is needed.
Isn’t there a way to define default library paths at compile time?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:6> ;
GDAL
December 22, 2016, 8:18am
8
Comment (by vince):
By the way, __unix__ is '''not''' defined by clang on MacOS, so I have to
replace all occurrences of __unix__ by __APPLE__.
It would be nice to have both in the code…
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:7> ;
GDAL
April 29, 2018, 4:55pm
9
Priority: normal | Milestone: 7.4.1
Changes (by neteler):
* milestone: 7.0.7 => 7.4.1
Comment:
Since GDAL 2.3.0 is due soon, I was wondering how up-to-date the code in
question is:
lib/raster/gdal.c
# ifdef __unix__
"libgdal.so.20",
"libgdal.so.1",
"libgdal.1.1.so",
"gdal.1.0.so",
"gdal.so.1.0",
"libgdal.so",
"libgdal1.6.0.so",
"libgdal1.7.0.so",
# endif
# ifdef _WIN32
"gdal202.dll",
"gdal201.dll",
"gdal200.dll",
"gdal111.dll",
"gdal110.dll",
"gdal19.dll",
"gdal18.dll",
"gdal17.dll",
"gdal16.dll",
"gdal15.dll",
"gdal11.dll",
"gdal.1.0.dll",
"libgdal-1.dll",
"gdal.dll",
# endif
NULL
int i;
This ticket is still open, so probably it should be all revisited now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:9> ;
GDAL
October 14, 2018, 11:17am
10
Priority: normal | Milestone: 7.4.2
Comment (by neteler):
Replying to [comment:9 neteler]:
question is:
> lib/raster/gdal.c
... any suggestion? This is now rather imminent.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:11> ;
GDAL
October 19, 2018, 2:58pm
11
gdal203.dll was added in r73573:73575
Not sure about other needed changes?
# ifdef __unix__
seems to be lagging behind?
@cmbarton : what about MacOS? Should libgdal.20.dylib or similar be added?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:12> ;
GDAL
March 15, 2019, 9:46am
12
Priority: normal | Milestone: 7.4.5
Comment (by vince):
This hasn't been corrected in 7.6
Also, I think the smartest way to handle this is to make the configure
script record the proper path to the GDAL library using gdal-config. Once
the access path is known, there is no need for that (silly?) function
enumerating all possible names and forgetting about some.
Also more ifdef __APPLE__ are needed here and there in the same file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:16> ;
GDAL
March 26, 2019, 11:43pm
13
@vince : do you see a chance to provide a patch?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:17> ;
GDAL
March 27, 2019, 7:26pm
14
Comment (by vince):
Yes, I could probably do that within a few days, if you’re willing to
integrate it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:18> ;
GDAL
March 27, 2019, 9:17pm
15
Replying to [comment:18 vince]:
integrate it.
Problem solving contributions are always welcome
Ticket URL: <https://trac.osgeo.org/grass/ticket/3230#comment:19> ;
