#3234: d.barscale: HTMLParser.HTMLParseError: EOF in middle of construct
Reporter: spareeth | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Compiling | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: Linux |
Hi
While I am trying to compile GRASS-trunk in a system with Ubuntu 14.04.3
LTS and is getting following errors:
Started compilation: Wed Dec 28 17:01:10 CET 2016
Errors in:
/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.barscale
/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.linegraph
/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.northarrow
/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.vect
/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/raster/r.colors
/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/vector/v.colors
/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/temporal/t.rast.colors
/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/man
cd "~/usr/local/src/grass7_trunk/display/d.barscale && make"
give this error and same for all the other modules listed above.
sajid.pareeth@disi-
rsnode08:/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.barscale$
make
VERSION_NUMBER=7.3.svn
/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/dist.x86_64-pc-linux-
gnu/tools/g.html2man.py
gnu/docs/html/d.barscale.html
gnu/docs/man/man1/d.barscale.1
File
"/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/dist.x86_64-pc-
linux-gnu/tools/g.html2man.py", line 71, in <module>
main()
File
linux-gnu/tools/g.html2man.py", line 50, in main
p.close()
File "/home/sajid.pareeth/usr/local/lib/python2.7/HTMLParser.py",
line 112, in close
self.goahead(1)
line 164, in goahead
self.error("EOF in middle of construct")
line 115, in error
raise HTMLParseError(message, self.getpos())
HTMLParser.HTMLParseError: EOF in middle of construct, at line 54,
column 8
make: ***
[/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/dist.x86_64-pc-
linux-gnu/docs/man/man1/d.barscale.1] Error 1
GRASS stable version compile without errors.
Sajid
Ticket URL: <https://trac.osgeo.org/grass/ticket/3234>
