#3236: v.db.select mixes areas and other geometries resulting in a wrong region
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.2.1
Component: Vector | Version: svn-trunk
Keywords: v.db.select | CPU: Unspecified
Platform: Unspecified |
v.db.select with option "print region" calls Vect_cidx_find_all with type
mask -1. This type mask matches lines and areas (see #3235). As a result -
output of it will be IDs of lines and IDs of areas. Subsequent calls to
Vect_get_line_type and Vect_get_line_box assume that Vect_cidx_find_all
has returned only line IDs and thus will read wrong line for matching
areas. The solution would be to change type mask to read "~GV_AREA"
instead of "-1".
I have not commited this as I would like if someone with greater
understanding of CIDX to take a look at it at first (together with #3235).
Here is sample data to test the issue. In both cases output should be
identical, still, as you can see, for "bad" map it is wrong.
echo "ORGANIZATION: Maris N
DIGIT DATE: 01/01/2017
DIGIT NAME: -
MAP NAME: fail
MAP DATE: 2017
MAP SCALE: 10000
OTHER INFO: Test polygons
ZONE: 0
MAP THRESH: 0.500000
VERTI:
B 4
15 10
10 10
10 15
15 15
C 1 1
12 12
1 3
C 1 1
17 12
1 4
B 4
15 10
20 10
20 15
15 15
B 2
15 10
15 15
" | v.in.ascii in=- format=standard output=bad --o
v.db.addtable map=bad
DIGIT NAME: -
MAP NAME: success
MAP DATE: 2017
MAP SCALE: 10000
ZONE: 0
VERTI:
B 4
15 10
10 10
10 15
15 15
B 4
15 10
20 10
20 15
15 15
B 2
15 10
15 15
C 1 1
12 12
1 3
C 1 1
17 12
1 4
" | v.in.ascii in=- format=standard output=good --o
v.db.addtable map=good
v.db.select -r map=good where=CAT=4
v.db.select -r map=bad where=CAT=4
Ticket URL: <https://trac.osgeo.org/grass/ticket/3236>
