[GRASS-dev] [GRASS GIS] #324: Ability to handle subgroups with general commands as all other datatypes
Reporter: nikos | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: subgroup, general commands | Platform: All
      Cpu: Unspecified |
I think it would be useful to extent all general commands so they handle
subgroups as all other datatypes.
Examples:
(a) g.list type=subgroup group=SomeGroup # to list the subgroups contained
in SomeGroup
(b) g.remove group=SomeGroup subgroup=SomeSubGroup # perhaps with a switch
to ensure only subgroup removal and avoid loosing the group
(c) g.rename group=SomeGroup subgroup=SomeSubGroup_new,SomeSubGroup_tested
Ticket URL: <http://trac.osgeo.org/grass/ticket/324&gt;
Resolution: | Keywords: subgroup, general commands
  Platform: All | Cpu: Unspecified
Changes (by neteler):
  * type: defect => enhancement
Ticket URL: <http://trac.osgeo.org/grass/ticket/324#comment:1&gt;
Comment (by glynn):
Replying to [ticket:324 nikos]:
This request suggests a misunderstanding about subgroups. They aren't
self-contained entities like groups or rasters or vectors; they're
properties of a group.
Using g.rename to modify a subgroup would be like using g.rename to change
a map's title. Using g.remove to remove a subgroup would be like using
g.remove to remove features from a vector map.
I suggest that this is resolved as "invalid".
Ticket URL: <http://trac.osgeo.org/grass/ticket/324#comment:2&gt;
Comment (by nikos):
Glynn, thank you for the explanation. Perhaps adding such functions in
i.group would make sense (?)
example: i.group group=pca -s # -s: list subgroups and not individual maps
added in the group
I'll try to make my point: I have lots of principal components that came
from different band combinations, why should I need to create as much
groups as the combinations from which they came from (in order to have an
easy overview for later classification tasks for example).
I only have one group called pca and in it lots of subgroups depending on
the initial band combination used to produce these components. Then I can
apply a classification using the same training set upon the different
subgroups. It takes less effort to "invent" names for groups/subgroups and
gives me the feel that its easier to review/check the data
(=groups/subgroups).
This is how I thought/think that subgroups are meaningful. Would you
recomment another "best practice" of GRASS groups/subgroups handling?
Ticket URL: <http://trac.osgeo.org/grass/ticket/324#comment:3&gt;
Comment (by glynn):
Replying to [comment:3 nikos]:
i.group (or another i.* module) would be the right place for anything
related to groups.
maps added in the group
That would probably be useful.
[snip]
The issue isn't about how to use groups/subgroups, but about where the
code required to do so belongs.
g.{list,copy,rename,remove} don't contain any knowledge about the various
entity types beyond what is contained in etc/element_list (other than a
special case for vectors, and one for the colr2 directory for rasters).
They just read the etc/element_list file to discover which files make up
the element, then list, copy, rename or remove the corresponding files.
Even the set of command-line options is built from the contents of the
element_list file.
If you want similar features for imagery subgroups, it would be better to
have something like:
i.subgroup [-l] group=... [remove=...] [copy=...] [rename=...]
The amount of code involved would be less (maybe significantly less) than
if the same features were added to the g.* commands, as you wouldn't need
code to override the "generic" behaviour of the g.* commands (e.g. when
g.remove sees "group=...", it will delete those groups, so you would have
to explicitly prevent that).
Ticket URL: <http://trac.osgeo.org/grass/ticket/324#comment:4&gt;
Comment (by nikos):
I did not remember that I posted this one already (ticket #134). May I
mark the current one as a duplicate?
Ticket URL: <http://trac.osgeo.org/grass/ticket/324#comment:5&gt;
      Type: enhancement | Status: closed
Resolution: duplicate | Keywords: subgroup, general commands
Changes (by hamish):
  * status: new => closed
  * resolution: => duplicate
Ticket URL: <http://trac.osgeo.org/grass/ticket/324#comment:6&gt;
