[GRASS-dev] [GRASS GIS] #3250: Build log is not visible for Mac OS on Travis CI
Reporter: wenzeslaus | Owner: grass-dev@…
Priority: normal | Milestone: 7.4.0
Component: Compiling | Version: svn-trunk
Keywords: travis-ci, osx, CI, testing, tests, | CPU: Unspecified
  build, logs |
Platform: MacOSX |
The automatic build on Travis for Mac would be much more helpful if it
would include the compilation details as it does for Linux.
There is not that much difference between failed and passed build:
Failing: https://travis-ci.org/GRASS-GIS/grass-ci/jobs/189871970
Passing: https://travis-ci.org/GRASS-GIS/grass-ci/jobs/190733886
I don't know if it related to the fact that `osx` build is using Homebrew
instead of building straight from the source code in the repository. It is
good that brew build gets tested but I would expect that it would be done
in the same way as for `linux`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3250&gt;
      Type: | Status: new
  enhancement |
Resolution: | Keywords: travis-ci, osx, CI, testing, tests,
       CPU: | build, logs
  Unspecified | Platform: MacOSX
Comment (by wenzeslaus):
In [changeset:"70483" 70483]:
#!CommitTicketReference repository="" revision="70483"
travis: remove the mac os build which goes through Homebrew
See https://lists.osgeo.org/pipermail/grass-dev/2017-January/084082.html
See #3250
Ticket URL: <https://trac.osgeo.org/grass/ticket/3250#comment:1&gt;
      Type: | Status: new
  enhancement |
  Priority: normal | Milestone: 7.6.2
       CPU: | build, logs
Comment (by neteler):
see also #2733
Ticket URL: <https://trac.osgeo.org/grass/ticket/3250#comment:7&gt;
