#3253: Main GUI fails to start when g.extension fails when fetching the addons
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: wxGUI | Version: svn-
Keywords: toolboxes, g.extension, startup, | releasebranch72
addons | CPU: Unspecified
Platform: Unspecified |
The GUI fails to start when `g.extension` fails during ''Addons'' toolbox
creation in `core/toolboxes.py`. GUI should continue just with an empty
''Addons'' toolbox.
After hitting OK, there is no further error or window visible. It does not
matter what if it is during GRASS start or with `g.gui` with or without
`-f`, same for 72 branch and trunk.
This is the error message in a dialog. The `g.extension` error is in the
command line which is not ideal because it should be at the same place as
the traceback.
List of addons cannot be obtained because g.extension failed.
Reason: Process ended with non-zero return code 1. See errors in the
(error) output.
File ".../gui/wxpython/core/toolboxes.py", line 507, in _getAddons
output = gcore.read_command('g.extension', quiet=True,
flags='qwertyuiopag')
File ".../etc/python/grass/script/core.py", line 474, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File ".../etc/python/grass/script/core.py", line 330, in handle_errors
returncode=returncode)
CalledModuleError: Module run None ['g.extension', '--q', '-qwertyuiopag']
ended with error
Process ended with non-zero return code 1. See errors in the (error)
output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3253>
