[GRASS-dev] [GRASS GIS] #3258: Launching in text mode should not automaticly use location/mapset from rc file
file
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Startup | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
I am using GRASS on my box in two modes - GUI when I'm on-site and text
when remote. This has shown a problem in current rc file logic:
* If location/mapset has been removed and it is provided during startup,
it sill generates an error message of missing location/mapset (took some
time till I understood why my batch processing is so verbose)
* If I have started with -text, subsequent runs will automatically start
in text mode with last used location/mapset. If I run GRASS from menu not
CLI, it is quite confusing to get thrown directly into some kind of
session without choosing one.
GRASS should not start if no location/mapset is specified as rc file could
be already outdated. Explicit is always better than implicit. rc should be
a hint not a rule, as users are not asked to "use the same location/mapset
next time" when it is created.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3258&gt;
file
Resolution: | Keywords:
Comment (by mlennert):
I wouldn't classify this as a defect. This was a design decision and
personally, I actually like the way it works. It requires a bit of getting
used to, but then it is quite nice.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3258#comment:1&gt;
file
  Priority: normal | Milestone: 7.4.1
Changes (by martinl):
* type: defect => enhancement
* milestone: 7.2.3 => 7.4.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3258#comment:4&gt;
file
  Priority: normal | Milestone: 8.0.0
Resolution: | Keywords: init rcfile gisrc
Changes (by wenzeslaus):
* keywords: => init rcfile gisrc
* milestone: 7.4.2 => 8.0.0
Comment:
This would be a change in behavior so 8.0, but perhaps the batch
processing should not lead to the rc file in home being updated and should
not use the rc file. Is that the problem?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3258#comment:6&gt;
