[GRASS-dev] [GRASS GIS] #3270: v.out.ogr: Append mode broken in G 7.2.1svn and 7.3
Reporter: sbl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Vector | Version: svn-releasebranch72
Keywords: v.out.ogr | CPU: Unspecified
Platform: Unspecified |
The following works in G 7.0 but not in G 7.2.1svn and G 7.3
v.out.ogr --q -m output=test.sqlite olayer=test input=soils_wake
lco="OVERWRITE=YES,GEOMETRY_NAME=geom,FID=fid,LAUNDER=YES" format=SQLite
v.out.ogr --q -mua output=test.sqlite olayer=test input=soils_wake
Error message on second command in G 7.2.1/7.3 is:
ERROR: option <output>: <test.sqlite> exists. To overwrite, use the
--overwrite flag
However, with --o the layer to append is deleted first and the following
eror message appears:
WARNING: OGR layer <test> already exists and will be overwritten
ERROR: OGR layer <test> not found
Probably related to:
https://trac.osgeo.org/grass/changeset/70204/
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270&gt;
Resolution: | Keywords: v.out.ogr
Comment (by sbl):
As a test I reverted locally
https://trac.osgeo.org/grass/changeset/70204/#file0
After that append mode works again in G7.2.1.
So, it seems changeset 70204 broke it...
Maybe the change should be reverted until a less conflicting solution is
found? I would refer the append functionality over a GUI button...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:1&gt;
  Reporter: sbl | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
* owner: grass-dev@… => martinl
* cc: grass-dev@… (added)
* status: new => assigned
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:2&gt;
Comment (by martinl):
In [changeset:"70500" 70500]:
#!CommitTicketReference repository="" revision="70500"
v.out.ogr: Append mode broken in G 7.2.1svn and 7.3 (see #3270)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:3&gt;
Should be solved in r70500. It changes API a bit, the `Flag` structure has
new attribute - `suppress_overwrite`. For relb72 we have two options:
a) backport (API change)
b) revert r70204.
I would vote for a) since GUI dialog is quite unusable since you need to
write path to output file by hand. Any opinion?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:4&gt;
Comment (by mlennert):
Replying to [comment:4 martinl]:
has new attribute - `suppress_overwrite`. For relb72 we have two options:
> b) revert r70204.
I wouldn't call it unusable (many of use have used it in that form for
years), just not very user-friendly. :wink:
IIUC, this is not a change of the user-visible API, but of the internal
API, or ? Then I don't have an issue with that.
However, (without having looked into this in detail) why can't this "just"
be directly dealt with within v.out.ogr main.c ?
Wouldn't something like this do the job ? :
Index: main.c
--- main.c (révision 70501)
+++ main.c (copie de travail)
@@ -488,23 +488,25 @@
      /* check if OGR layer exists */
      overwrite = G_check_overwrite(argc, argv);
      found = FALSE;
- for (i = 0; i < OGR_DS_GetLayerCount(Ogr_ds); i++) {
- Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
- Ogr_field = OGR_L_GetLayerDefn(Ogr_layer);
- if (G_strcasecmp(OGR_FD_GetName(Ogr_field),
options.layer->answer))
- continue;
- found = TRUE;
- if (!overwrite && !flags.append->answer) {
- G_fatal_error(_("Layer <%s> already exists in OGR data source
'%s'"),
- options.layer->answer, options.dsn->answer);
+ if (!flags.append->answer) {
+ for (i = 0; i < OGR_DS_GetLayerCount(Ogr_ds); i++) {
+ Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
+ Ogr_field = OGR_L_GetLayerDefn(Ogr_layer);
+ if (G_strcasecmp(OGR_FD_GetName(Ogr_field),
+ continue;
+ found = TRUE;
+ if (!overwrite) {
+ G_fatal_error(_("Layer <%s> already exists in OGR data
source '%s'"),
+ options.layer->answer, options.dsn->answer);
+ else if (overwrite) {
+ G_warning(_("OGR layer <%s> already exists and will be
overwritten"),
+ options.layer->answer);
+ OGR_DS_DeleteLayer(Ogr_ds, i);
+ break;
- else if (overwrite) {
- G_warning(_("OGR layer <%s> already exists and will be
overwritten"),
- options.layer->answer);
- OGR_DS_DeleteLayer(Ogr_ds, i);
- break;
      if (flags.append->answer && !found) {
         G_warning(_("OGR layer <%s> doesn't exists, "
since we don't need to worry about overwriting at all when we are in
append mode, or ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:5&gt;
Replying to [comment:5 mlennert]:
https://grass.osgeo.org/programming7/structFlag.html
Probably yes. My intend was to introduce generic solution how to suppress
overwrite check. Any idea about other modules which could have benefit
from that? If there is only G72:v.out.ogr we could probably go for local
modification as you suggests.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:6&gt;
Replying to [comment:6 martinl]:
internal API, or ? Then I don't have an issue with that.
Yes, this is what I call the internal API. Users are generally not
confronted with this. In my understanding our no-API change rule is about
module API, not internal API, as GRASS GIS is generally not used as a
library.
suppress overwrite check. Any idea about other modules which could have
benefit from that? If there is only G72:v.out.ogr we could probably go for
local modification as you suggests.
I can't think of another module where one specific choice warrants an
override of overwrite settings...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:7&gt;
this patch worked for you? The overwrite check is done earlier by parser
(since output is not G_OPT_F_OUTPUT)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:8&gt;
Replying to [comment:8 martinl]:
I didn't try. It was just the result of a quick look at the code, not a
real patch.
> The overwrite check is done earlier by parser (since output is not
G_OPT_F_OUTPUT)?
Yes, right. So, you are probably right that this needs a parser-level
solution.
Sorry for the noise...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:9&gt;
In [changeset:"70617" 70617]:
#!CommitTicketReference repository="" revision="70617"
libgis: add suppress overwrite attribute (see #3270)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:10&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.out.ogr
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"70618" 70618]:
#!CommitTicketReference repository="" revision="70618"
v.out.ogr: Append mode broken in G 7.2.1svn and 7.3 (closes #3270)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:11&gt;
