[GRASS-dev] [GRASS GIS] #3275: wxGUI: encoding error when saving workspace
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: wxGUI | Version: svn-trunk
Keywords: wxGUI workspace encoding | CPU: Unspecified
Platform: Unspecified |
Trying to save my workspace, I get the following error:
Échec d'écriture des paramètres de l'espace de travail courant.
Raison: 'ascii' codec can't encode character u'\u20ac' in position 34:
ordinal not in range(128)
   File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/gui/wxpython/lmgr/frame.py", line 1634, in SaveToWorkspaceFile
     WriteWorkspaceFile(lmgr=self, file=tmpfile)
gnu/gui/wxpython/core/workspace.py", line 906, in __init__
     self.__writeOverlay(mapdisp)
gnu/gui/wxpython/core/workspace.py", line 1522, in __writeOverlay
     self.__writeOverlayParams(disp_size, overlay.cmd, overlay.coords)
gnu/gui/wxpython/core/workspace.py", line 1570, in __writeOverlayParams
     self.file.write('%s<value>%s</value>\n' % (' ' * self.indent,
prm.split("=", 1)[1]))
UnicodeEncodeError: 'ascii' codec can't encode character u'\u20ac' in
position 34: ordinal not in range(128)
The weird part is that I don't even know where I would have a non-ascii
character. Maybe some translation has happened of parameters for the
workspace parameter file ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3275&gt;
Resolution: | Keywords: wxGUI workspace encoding
Comment (by mlennert):
Vaclav made me realize that I did have a non-ascii character in my
display: u'\u20ac' is a Euro sign.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3275#comment:1&gt;
Replying to [comment:1 mlennert]:
This does not make this less an error, though. I suppose this is linked to
the GSoC cartography work trying to save more elements of the current map
display ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3275#comment:2&gt;
Comment (by annakrat):
In [changeset:"70531" 70531]:
#!CommitTicketReference repository="" revision="70531"
wxGUI: encode values when saving workspace with overlays (see #3275)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3275#comment:3&gt;
Comment (by marisn):
There have been fixes for #3340 related to encoding. At the moment
loading/saving workspace with various non-latin chars seems to work fine.
Can this be closed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3275#comment:4&gt;
  Priority: normal | Milestone: 7.2.2
Changes (by mlennert):
* milestone: 7.2.1 => 7.2.2
Comment:
Replying to [comment:4 marisn]:
Can this be closed?
r70531 still needs backporting so I would keep this ticket open until that
has happened.
Changing milestone to 7.2.2 to harmonize with the rest.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3275#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxGUI workspace encoding
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Backported in r71057.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3275#comment:6&gt;
