[GRASS-dev] [GRASS GIS] #3284: Imported kml file fails to generate JSON compliant output to v.what
Reporter: geografik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Database | Version: 7.2.0
Keywords: v.what, kml, 'valid JSON format' | CPU: OSX/Intel
Platform: MacOSX |
I have imported a kml file that contains contours of a feature of
interest. Functionally an x,y,z data set. It displays correctly in GRASS.
When queried to determine the value of z, the attached error is given that
indicates a lack of conformance with JSON formatting. The values of z are
given for the feature in the error message but additional processing such
as v.to.rast does not work. GRASS is able to label the contours
correctly. Using the attribute table manager is not much help - it
produces an error that indicates 'Inconsistent number of columns in
table'.
I see that there is a bug report (3133) that reflects the same problem but
has been fixed in 7.0.5 - I'm getting the 'same' error in 7.3.svn. (on OS
X 10.10.5)
The error message is too long to fit on the monitor - and is not
scrollable, so the full content is not visible.
Anna Petrášová diagnosed the problem as multiline strings in the
'description' column and suggested deleting it. That resolved the problem
but is not a complete solution where that column is needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3284&gt;
Resolution: | Keywords: v.what, kml, 'valid JSON format'
       CPU: OSX/Intel | Platform: MacOSX
Changes (by geografik):
* Attachment "Screen Shot 2017-02-12 at 9.11.07 AM.png" added.
screenshot of error output
Comment (by neteler):
The same happens with the Sentinel-2 tile index KML: the quotes seem not
to be properly escaped.
Data:
https://sentinel.esa.int/documents/247904/1955685/S2A_OPER_GIP_TILPAR_MPC__20151209T095117_V20150622T000000_21000101T000000_B00.kml
Ticket URL: <https://trac.osgeo.org/grass/ticket/3284#comment:1&gt;
  Priority: normal | Milestone: 7.4.4
Changes (by neteler):
* milestone: 7.2.4 => 7.4.4
Comment:
Did you try lately?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3284#comment:6&gt;
  Priority: normal | Milestone: 7.4.5
* milestone: 7.4.4 => 7.4.5
Ticket URL: <https://trac.osgeo.org/grass/ticket/3284#comment:7&gt;
Comment (by mmetz):
Should be fixed in trunk r74048 and relbr r74448.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3284#comment:8&gt;
