#3286: Add Line_height as a valid attribute in v.to.db
Reporter: geografik | Owner: grass-dev@…
Priority: normal | Milestone: 7.2.1
Component: Database | Version: 7.2.0
Keywords: Line_height, v.in.db, kml | CPU: All
Platform: All |
Imported kml files that include elevation data are structured generally as
shown below in GRASS (this is an example of a contour line):
Elevation data is maintained in the Line_height field which is not a
recognized attribute, and therefor precludes any further use of these data
in GRASS - beyond simple display and labling. 3D analysis, for example,
is not possible. The suggested improvement to v.to.db would add
Line_height to the list of attributes considered in this module so that
the elevation data could become part of the recognized feature attributes
and be useful in other modules.
Resolution: | Keywords: Line_height, v.in.db, kml
CPU: All | Platform: All
Comment (by mlennert):
Replying to [ticket:3286 geografik]:
as shown below in GRASS (this is an example of a contour line):
> east, north: -79.7630759471, 39.0874586371
> DBT@corH:
> Type: Line
> Length: 275.746
> Line_height: 698.602997
> Layer: 1
> Category: 885
> Driver: sqlite
> Database: /Users/sesMacBook/grassdata/KML/corH/sqlite/sqlite.db
> Table: DBT
> Key_column: cat
> Attributes:
> cat: 885
> cat_: 885
> tessellate: -1
> extrude: -1
> visibility: -1
Actually, Line_height is not a "field" in the data. v.what calculates the
minimum and the maximum height of all the vertices of a line and either
outputs both, or, if they are equal, only one value.
The question this raises, therefore, is: which "height" is the most
relevant for a line ? Should it be the mean height of all vertices ?
Should v.to.db provide lheight_min, lheight_mean and lheight_max ?
data in GRASS - beyond simple display and labling. 3D analysis, for
example, is not possible. The suggested improvement to v.to.db would add
New description:
Comment (by mmetz):
Replying to [comment:1 mlennert]:
generally as shown below in GRASS (this is an example of a contour line):
> > DBT@corH:
> > Type: Line
> > Length: 275.746
> > Layer: 1
> > Category: 885
> > Driver: sqlite
> > Table: DBT
> > Key_column: cat
> > Attributes:
> > cat: 885
> > cat_: 885
> > tessellate: -1
> > extrude: -1
> > visibility: -1
the minimum and the maximum height of all the vertices of a line and
either outputs both, or, if they are equal, only one value.
The correct mean height of a line is the sum of the weighted averages of
each line segment divided by the sum of weights. The weight of a line
segment is its 3D length.
