[GRASS-dev] [GRASS GIS] #3289: Setting delete_empty=True register_map_object_list() when using vector map ends up in crashing
ends up in crashing
Reporter: lrntct | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Temporal | Version: 7.2.0
Keywords: stvds register | CPU: x86-64
Platform: Linux |
When trying to register a list of VectorDataset objects in a STVDS
using register_map_object_list(delete_empty=True), it ends up with the
following error:
   File "/usr/lib/grass72/etc/python/grass/temporal/register.py", line
480, in register_map_object_list
     if map_layer.metadata.get_min() is None and \
AttributeError: 'VectorMetadata' object has no attribute 'get_min'
A minimum working example is attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3289&gt;
ends up in crashing
Resolution: | Keywords: stvds register
       CPU: x86-64 | Platform: Linux
Changes (by lrntct):
* Attachment "register_test.py" added.
ends up in crashing
  Priority: normal | Milestone: 7.2.3
Comment (by veroandreo):
is this still an issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3289#comment:3&gt;
