#3291: Zoom to selected feature not working when cat is not the first column
Reporter: hcho | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: wxGUI | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: Linux |
When cat is not the first column in the attribute table, select and zoom
to feature in the attribute table manger does not work. In the Console
table, I can see the following traceback:
File "dist.x86_64-pc-linux-
gnu/gui/wxpython/dbmgr/base.py", line 1923, in
OnDataDrawSelectedZoom
self._drawSelected(zoom=True)
gnu/gui/wxpython/dbmgr/base.py", line 1779, in _drawSelected
cats = map(int, fn())
ValueError
invalid literal for int() with base 10: '3215929.3665139'
The key column is not always the first column, so this assumption should
be avoided.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3291>
