[GRASS-dev] [GRASS GIS] #3294: g.gui.tplot: error when trying to plot a STVDS
Reporter: lrntct | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: wxGUI | Version: 7.2.0
Keywords: | CPU: x86-64
Platform: Linux |
When using g.gui.tplot to plot a time-series of a point in a STVDS, I
encounter the following issue:
When selecting the stvds in the GUI, a GUI message appears, saying:
Invalid input temporal dataset
And the console displays a message from t.vect.list:
ERROR: t.vect.list: Sorry, <s> is not a valid flag
If nonetheless trying to plot a value, the following error message appears
in the console, and nothing is plotted:
   File "/usr/lib/grass72/gui/wxpython/tplot/frame.py", line 759, in
OnRedraw
     self._redraw()
   File "/usr/lib/grass72/gui/wxpython/tplot/frame.py", line 770, in
_redraw
     self._getSTVDData(self.datasetsV)
   File "/usr/lib/grass72/gui/wxpython/tplot/frame.py", line 480, in
_getSTVDData
     cats = self._getExistingCategories(rows[0]['name'], cats)
   File "/usr/lib/grass72/gui/wxpython/tplot/frame.py", line 384, in
     for cat in cats:
TypeError: 'NoneType' object is not iterable
Ticket URL: <https://trac.osgeo.org/grass/ticket/3294&gt;
Resolution: | Keywords:
       CPU: x86-64 | Platform: Linux
Comment (by lrntct):
Might be related to [69686]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3294#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Good catch, r69686 now backported in r70648. Thanks!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3294#comment:2&gt;
Hello,
Thanks for the fast answer.
I applied the patch, but I get another error when trying to plot the STVDS:
  File "/usr/lib/grass72/gui/wxpython/tplot/frame.py", line 759, in OnRedraw
    self._redraw()
  File "/usr/lib/grass72/gui/wxpython/tplot/frame.py", line 770, in _redraw
  File "/usr/lib/grass72/gui/wxpython/tplot/frame.py", line 499, in _getSTVDData
    lay = int(row['layer'])
TypeError: int() argument must be a string or a number, not 'NoneType'
I don't know if it's related, but my maps have two layers.
t.vect.db.select is working correctly.
Laurent
2017-02-20 13:34 GMT-06:00 GRASS GIS <trac@osgeo.org>:
Comment:
      Type: defect | Status: reopened
Changes (by lrntct):
* status: closed => reopened
* resolution: fixed =>
Comment:
After applying the patch, I get another error when trying to plot the
STVDS:
OnRedraw
     self._redraw()
_redraw
_getSTVDData
The maps inside the STVDS have two layers.
t.vect.db.select is working correctly with that STVDS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3294#comment:3&gt;
  Priority: normal | Milestone: 7.2.3
Comment (by lucadelu):
In [changeset:"72485" 72485]:
#!CommitTicketReference repository="" revision="72485"
g.gui.tplot: resolved problem with stdvs when no categories are set, see
#3294
Ticket URL: <https://trac.osgeo.org/grass/ticket/3294#comment:6&gt;
In [changeset:"72486" 72486]:
#!CommitTicketReference repository="" revision="72486"
#3294
Ticket URL: <https://trac.osgeo.org/grass/ticket/3294#comment:7&gt;
In [changeset:"72490" 72490]:
#!CommitTicketReference repository="" revision="72490"
#3294
Ticket URL: <https://trac.osgeo.org/grass/ticket/3294#comment:8&gt;
  Priority: normal | Milestone: 7.8.0
Component: wxGUI | Version: svn-trunk
Changes (by veroandreo):
* version: 7.2.0 => svn-trunk
* milestone: 7.2.4 => 7.8.0
Comment:
Changing milestone. I get the last error reported:
   File "/home/veroandreo/software/grass7_trunk/dist.x86_64
-pc-linux-gnu/gui/wxpython/tplot/frame.py", line 882, in
OnRedraw
self._redraw()
-pc-linux-gnu/gui/wxpython/tplot/frame.py", line 893, in
_redraw
-pc-linux-gnu/gui/wxpython/tplot/frame.py", line 566, in
_getSTVDData
TypeError
OnRedraw
self._redraw()
_redraw
_getSTVDData
TypeError
Ticket URL: <https://trac.osgeo.org/grass/ticket/3294#comment:11&gt;
