#3306: Query vector maps gives error
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
When using the wxGUI vector attribute query tool to get the values for a
vector layer, I am getting an error (but only for polygons, querying
points and lines seem to work?). For example, trying to query the geology
layer in the NC dataset:
Failed to query vector map(s) <geology@PERMANENT>. Check database settings
and topology.
Reason: "198808.723525"}}]}]}]}
File "/usr/local/grass7/grass-7.3.svn/gui/wxpython/mapdisp/frame.py",
line 955, in QueryMap
distance=qdist, encoding=encoding, multiple=True)
File
"/usr/local/grass7/grass-7.3.svn/etc/python/grass/script/vector.py", line
413, in vector_what
raise ScriptError(_("v.what output is not valid JSON format:\n
{ret}").format(ret=ret))
ScriptError: v.what output is not valid JSON format:
{"Coordinates": {"East": "634570.206825", "North": "223191.644261"},
"Maps": [
{"Map": "geology",
"Mapset": "PERMANENT",
"Features": [
"Type": "Area",
"Sq_Meters": 261215323.454,
"Hectares": 26121.532,
"Acres": 64547.712,
"Sq_Miles": 100.8558,
"Categories": [
{"Layer": 1, "Category": 217,
"Driver": "sqlite",
"Database":
"/home/paulo/Data/GRASSdb/nc_spm_08_grass7/PERMANENT/sqlite/sqlite.db",
"Table": "geology",
"Key_column": "cat",
"Attributes": {"cat": "217",
"onemap_pro": "261215328",
"PERIMETER": "198808.71875",
"GEOL250_": "218",
"GEOL250_ID": "217",
"GEO_NAME": "CZfg",
"SHAPE_area": "261215323.454",
"SHAPE_len": "198808.723525"}}]}]}]}
Not sure if this has anything to do with ticket #3133? Using trunk r70721
Ticket URL: <https://trac.osgeo.org/grass/ticket/3306>
