[GRASS-dev] [GRASS GIS] #3309: Avoid errors in parallel creation of tempfiles
Reporter: sbl | Owner: grass-dev@…
Priority: normal | Milestone: 7.2.1
Component: LibGIS | Version: svn-releasebranch72
Keywords: G_tempfile() | CPU: Unspecified
Platform: Unspecified |
When tempfiles are created in parallel, conflicts and thus fatal errors
can arise when two processes try to create the .tmp/HOST dir at the same
time:
https://lists.osgeo.org/pipermail/grass-dev/2017-March/084471.html
The conflict seems to arise only from the directory.
So, maybe it could help if the directory is created at the start of a
GRASS session and removed only when the GRASS session is closed (exit)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3309&gt;
Resolution: | Keywords: G_tempfile()
Comment (by mlennert):
Replying to [ticket:3309 sbl]:
time:
Now that you mention it, I can confirm that I've also been confronted to
such errors when running commands in parallel that create temp files. So
+1 to needing a solution.
I don't know though if the best is to create this directory once and for
all at the startup, or whether the tempfile routines in lib/gis/tempfile.c
could be modified to avoid such race conditions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3309#comment:1&gt;
Comment (by mmetz):
Replying to [comment:1 mlennert]:
errors can arise when two processes try to create the .tmp/HOST dir at the
same time:
Strange. When starting GRASS in text or GUI mode, the .tmp/HOST folder is
automatically created, i.e. the error
ERROR: Unable to make mapset element .tmp/HOST
(/grassdata/ETRS_33N/timseries/.tmp): File exists
should not happen, at least not in trunk and relb72.
You could use
rm -f "`g.tempfile pid=$$`"
before running xargs, just to make sure that .tmp/HOST has been created.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3309#comment:2&gt;
Comment (by sbl):
I run the xargs command in a GRASS_BATCH_JOB in case that can be of
relevance...
Will test if
helps and report back...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3309#comment:3&gt;
Comment (by sbl):
For the record:
Running
in advance works around the issue.
Using GRASS 7.2.1svn (r70188) in BATCH mode I do get the error message
above. But if I run g.tempfile and make sure that the tmp directory is
created before I run r.in.gdal through xargs, everything works just fine!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3309#comment:4&gt;
  Priority: normal | Milestone: 7.4.2
Comment (by neteler):
Does this issue persist in GRASS GIS 7.6.svn?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3309#comment:9&gt;
Resolution: | Keywords: G_tempfile() startup init
Changes (by wenzeslaus):
* keywords: G_tempfile() => G_tempfile() startup init
Comment:
Replying to [comment:9 neteler]:
Please, if you can, test trunk (7.7) too - a lot of changes to temporary
directory handling (#613, #1286, #3635, ...). And if possible, please,
test also `GRASS_BATCH_JOB` versus `--exec`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3309#comment:10&gt;
