[GRASS-dev] [GRASS GIS] #331: extend the vector modell to be able to calculate real circular segments and circles => for calculating real circular buffers of points
Reporter: mlechner | Owner: grass-dev@lists.osgeo.org
Priority: major | Milestone: 7.0.0
Component: default | Version: unspecified
Keywords: vector model curve circle buffer | Platform: Unspecified
      Cpu: Unspecified |
It would be interesting to extend the grass vector model to be able to
construct curves for using them to create real circular buffers instead of
approximating them using several vertices.
I just was wondering - isn't it more effectice saving a buffer using one
vertice and a "curved line" than using several points and approximate the
circle.
An appproximated buffer could still be in the data - only newly calculated
buffers are more correct then.
Ticket URL: <http://trac.osgeo.org/grass/ticket/331&gt;
  Priority: minor | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: vector model curve circle buffer
  Platform: All | Cpu: All
Changes (by hamish):
  * priority: major => minor
  * platform: Unspecified => All
  * version: unspecified => svn-trunk
  * component: default => Vector
  * cpu: Unspecified => All
Comment:
Replying to [ticket:331 mlechner]:
> able to construct curves for using them to create real circular
> buffers instead of approximating them using several vertices.
> using one vertice and a "curved line" than using several points
> and approximate the circle.
> calculated buffers are more correct then.
I remember some years ago seeing a presentation about a similar idea. The
talk was entitled “The circle tree – a hierarchical structure for
efficient storage, access and multi-scale representation of spatial data”,
by Antoni Moore.
http://www.business.otago.ac.nz/SIRC/conferences/2002_SIRC/17_Moore.pdf
(and also another talk at SIRC 2003)
Tony's office is just down the hall, if needed I can ask him where it
lead. ISTR they had a prototype and did some efficacy testing.
(or you can just use that as scholar.google search terms for
publications...)
perhaps this wish is "easier said than done".
see also the symbol library, which has a hybrid cartesian/polar polyline
input method.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/331#comment:1&gt;
Comment (by glynn):
Replying to [comment:1 hamish]:
Very much so. The problem isn't creating or storing curves, but the fact
that every vector module would need to be able to handle paths which
contain curved segments.
Certain operations are much more complex for curves than for straight line
segments, e.g. testing which side of the line a point falls on,
calculating the intersection between segments, etc.
It would be possible to provide a mechanism whereby the vector libraries
automatically convert a curve to a sequence of straight line segments,
with the accuracy determined by either the calling module, a run-time
configuration variable, or a default value stored in the map. However,
this creates other issues, e.g. the results would differ depending upon
the accuracy chosen.
Another option would be to allow lines to be "tagged" with an indication
that they represent sampled curves. Individual modules could then
(optionally) interpolate the paths to a higher detail level.
Or would could just have a separate module (or an extension to v.split)
which subdivides vectors by treating them as sampled curves rather than a
sequence of straight lines.
Ticket URL: <http://trac.osgeo.org/grass/ticket/331#comment:2&gt;
