[GRASS-dev] [GRASS GIS] #3314: URL as input for r.unpack and v.unpack
Reporter: wenzeslaus | Owner: grass-dev@…
Priority: trivial | Milestone: 7.4.0
Component: Default | Version: unspecified
Keywords: r.unpack v.unpack t.rast.import | CPU: Unspecified
  t.vect.import r.in.xyz v.in.ascii r.in.ascii |
  r3.in.xyz URL download |
Platform: Unspecified |
The following modules accept a local file as **input** parameter, they
could also accept a general URL (similarly to G7:g.extension) and download
the archive from the Internet.
* G7:r.unpack
* G7:v.unpack
The would be helpful in cases when users needs to use a file stored
somewhere online. The whole thing could be done in one step (from GUI or
command line) if `input='http://example.com/araster.pack’` is supported.
There is no equivalent of `r.pack-r.unpack` for 3D rasters or imagery
groups, but there are "import" modules for temporal datasets which can
potentially use same improvement:
* G7:t.rast.import
* G7:t.vect.import
Possible criticism: There are many modules which just take a file (as
opposed to more complicated inputs like in G7r.in.gdal/G7r.import) for
example G7:r.in.xyz or G7:v.in.ascii which can use the same, but they are
in C, not in Python, and adding this functionality would be much more
complicated. Hence, it is clear that the proposed features depends on the
language used for implementation, not purely on design decision.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3314&gt;
