[GRASS-dev] [GRASS GIS] #3339: postgis topology: missing relations
Reporter: martinl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: LibVector | Version: unspecified
Keywords: postgis topology | CPU: Unspecified
Platform: Unspecified |
GRASS currently wrongly interprets relation between feature table and
topological primitives (nodes, edges, faces). The correct relation is
defined by `relation` table in topo schema which is currently empty.
test=# SELECT * from topo_sample_invalid_geom_in_pg.relation;
  topogeo_id | layer_id | element_id | element_type
(0 rows)
Correct table for 3 polygons:
test=# SELECT * from topo_sample_invalid_geom_in_pg1.relation;
           1 | 1 | 1 | 3
           2 | 1 | 2 | 3
           3 | 1 | 30 | 3
(3 rows)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3339&gt;
  Priority: normal | Milestone: 7.2.4
Resolution: | Keywords: postgis topology
Changes (by martinl):
* Attachment "libvect_postgis_topo_relations.diff" added.
  Priority: normal | Milestone: 7.8.0
* milestone: 7.2.4 => 7.8.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3339#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: postgis topology
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"74013" 74013]:
#!CommitTicketReference repository="" revision="74013"
postgis topology: missing relations, fix #3339
Ticket URL: <https://trac.osgeo.org/grass/ticket/3339#comment:6&gt;
