[GRASS-dev] [GRASS GIS] #3340: wxGUI: encoding error when saving a workspace with vector that has accents in legend_label
in legend_label
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: wxGUI | Version: svn-trunk
Keywords: legend_label workspace | CPU: Unspecified
Platform: Unspecified |
Whenever I have a vector map with a legend_label with accents, such as:
d.vect map=roadsmajor@PERMANENT type=point,line,boundary,area,face width=1
legend_label=Chaussées
I cannot save the workspace file because of an encoding error:
Échec d'écriture des paramètres de l'espace de travail courant.
Raison: 'ascii' codec can't encode character u'\xe9' in position 33:
ordinal not in range(128)
   File "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/gui/wxpython/lmgr/frame.py", line 1649, in SaveToWorkspaceFile
     WriteWorkspaceFile(lmgr=self, file=tmpfile)
gnu/gui/wxpython/core/workspace.py", line 900, in __init__
     self.__writeLayer(mapTree, item)
gnu/gui/wxpython/core/workspace.py", line 993, in __writeLayer
     (' ' * self.indent, self.__filterValue(val)))
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 33: ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340&gt;
in legend_label
Resolution: | Keywords: legend_label workspace
Comment (by annakrat):
In [changeset:"70979" 70979]:
#!CommitTicketReference repository="" revision="70979"
wxGUI: fix encoding, see #3340
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:1&gt;
in legend_label
  Priority: normal | Milestone: 7.2.2
Changes (by annakrat):
* milestone: 7.2.1 => 7.2.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:2&gt;
in legend_label
Comment (by mlennert):
Replying to [comment:1 annakrat]:
Works great. Thanks for the quick fix !
You changed the milestone to 7.2.2. I had the feeling that this is a quite
small and pretty non-invasive fix of a standard bug. Don't you think it
could still go into 7.2.1 ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:3&gt;
in legend_label
Comment (by marisn):
Replying to [comment:3 mlennert]:
Sort of. Related issue seems to be #3275
I tested various text elements and managed to save workspace just fine,
still loading fails, although the error might come form a different area
(I'll attach file for testing):
   File "dist.x86_64-pc-linux-gnu/gui/wxpython/lmgr/frame.py", line 1362,
in
OnWorkspaceOpen
self.LoadWorkspaceFile(filename)
   File "dist.x86_64-pc-linux-gnu/gui/wxpython/lmgr/frame.py", line 1512,
in
LoadWorkspaceFile
mapdisplay[i].AddBarscale(overlay['cmd'])
   File "dist.x86_64-pc-linux-gnu/gui/wxpython/mapdisp/frame.py", line
1224, in
AddBarscale
cmd, completed=(self.GetOptData, None, None))
   File "dist.x86_64-pc-linux-gnu/gui/wxpython/gui_core/forms.py", line
2890, in
ParseCommand
get_dcmd=get_dcmd, layer=layer)
534, in __init__
frame=self)
1313, in __init__
win.SetValue(str(value))
UnicodeEncodeError
'ascii' codec can't encode characters in position 0-6:
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:4&gt;
in legend_label
Changes (by marisn):
* Attachment "rm_enctest.gxw" added.
Encoding test for workspace loading
in legend_label
In [changeset:"70985" 70985]:
#!CommitTicketReference repository="" revision="70985"
wxGUI: fix encoding problems, see #3340
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:5&gt;
in legend_label
Replying to [comment:5 annakrat]:
Now saving and loading seems to work fine. I think it has also fixed
#3275.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:6&gt;
in legend_label
quite small and pretty non-invasive fix of a standard bug. Don't you think
it could still go into 7.2.1 ?
Too close right now, I wouldn't be comfortable doing that especially
because I haven't tested it on Windows.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:7&gt;
in legend_label
Replying to [comment:7 annakrat]:
Ok. I agree. So we'll leave this open as a reminder for backport.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:8&gt;
in legend_label
Is there some documentation about best practices in GUI programming
concerning handling of encoding ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:9&gt;
in legend_label
      Type: defect | Status: closed
Resolution: fixed | Keywords: legend_label workspace
* status: new => closed
* resolution: => fixed
Comment:
Backported in r71057.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:10&gt;
