[GRASS-dev] [GRASS GIS] #3343: v.label.sa broken and duplicated in trunk and addons
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Priority: trivial | Milestone: 7.4.0
Component: Addons | Version: svn-trunk
Keywords: v.label.sa, FTLIB, FreeType, | CPU: Unspecified
  compilation |
Platform: Unspecified |
v.label.sa code is both in trunk and in addons repository. The versions
are the same except for few characters. The compilation is disabled in
trunk and it is broken in addons with:
labels.c: In function ‘labels_init’:
labels.c:88:5: error: implicit declaration of function
‘find_font_from_freetypecap’ [-Werror=implicit-function-declaration]
labels.c:88:14: warning: assignment makes pointer from integer without a
cast [enabled by default]
labels.c:100:5: error: implicit declaration of function ‘free_fontcap’
In G6 the compilation is conditional:
REQUIRESFT = v.label.sa
ifneq ($(strip $(FTLIB)),)
     SUBDIRS += $(REQUIRESFT)
endif
and the `v.label.sa` code in G6 contains the missing function
`find_font_from_freetypecap()`.
The `free_fontcap` function is in `lib/driver/driverlib.h` in G7.
I suggest to remove the trunk version. Fixing the code would be nice of
course.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3343&gt;
Resolution: | Keywords: v.label.sa, FTLIB, FreeType,
       CPU: | compilation
  Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3343 wenzeslaus]:
With r71061, the compile errors in `v.label.sa` are fixed and the versions
in trunk and addons have been sync'ed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3343#comment:1&gt;
       CPU: | compilation
Comment (by neteler):
Re-enabled module in r71684.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3343#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.label.sa, FTLIB, FreeType,
       CPU: | compilation
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3343#comment:3&gt;
