#3350: wxGUI: map decorations are not removed when creating new workspace (Ctrl-N)
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: wxGUI | Version: svn-trunk
Keywords: wxGUI display decorations | CPU: Unspecified
Platform: Unspecified |
Map decorations are not remove from a map display when one pushes the
button to create a new workspace (Ctrl-N).
IMHO, creating a new workspace means starting from scratch and all
decorations should be removed. In the current state, the user has to
manually remove each of the decorations.
Resolution: | Keywords: wxGUI display decorations
Comment (by annakrat):
In [changeset:"71165" 71165]:
#!CommitTicketReference repository="" revision="71165"
wxGUI: remove decorations when creating new workspace, see #3350
In [changeset:"71168" 71168]:
#!CommitTicketReference repository="" revision="71168"
wxGUI: remove decorations when creating new workspace, see #3350 (merge
from trunk, r71165)
