[GRASS-dev] [GRASS GIS] #3353: r.support metadata: accents not supported in some fields
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: LibGIS | Version: svn-trunk
Keywords: support files r.support translation | CPU: Unspecified
Platform: Unspecified |
g.copy rast=elevation,myelev
r.support myelev source1="Tést of aççented chàracters" description="Tést
of aççented chàracters" history="Tést of aççented chàracters" title="Tést
r.info -e myelev
map=myelev
mapset=user1
location=nc_spm_08
database=/data/GRASS/DATA7
date="Tue Nov 7 01:09:51 2006"
creator="helena"
title="Tést of aççented chàracters"
timestamp="none"
units="none"
vdatum="none"
source1="Tst of aented chracters"
source2=""
description="Tst of aented chracters"
comments="r.proj input="ned03arcsec" location="northcarolina_latlong"
mapset="\helena" output="elev_ned10m" method="cubic" resolution=10Tést of
i.e. accents are supported in title and comments, but not in source or in
description.
This last point, also creates an issue with the default description, which
contains a translatable string, which in French is translated using
accents:
#: ../lib/raster/history.c:235
#, c-format
msgid "generated by %s"
msgstr "généré par %s"
Which results in
"gnr par".
Is there any way to allow accents in these fields ? If not, then I guess
the default description string should not be translatable, and the info
should at least be mentioned in the man page.
Here are my locale settings:
> locale
LANG=fr_BE
LANGUAGE=fr_BE
LC_CTYPE=fr_BE.UTF-8
LC_NUMERIC=C
LC_TIME=fr_BE.UTF-8
LC_COLLATE=fr_BE.UTF-8
LC_MONETARY=fr_BE.UTF-8
LC_MESSAGES=fr_BE.UTF-8
LC_PAPER=fr_BE.UTF-8
LC_NAME=fr_BE.UTF-8
LC_ADDRESS=fr_BE.UTF-8
LC_TELEPHONE=fr_BE.UTF-8
LC_MEASUREMENT=fr_BE.UTF-8
LC_IDENTIFICATION=fr_BE.UTF-8
LC_ALL=
Ticket URL: <https://trac.osgeo.org/grass/ticket/3353&gt;
