#3354: errors building re: grass/src/grass-7.2.1/lib/python/ctypes
Reporter: saultdon | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Compiling | Version: 7.2.1
Keywords: | CPU: x86-64
Platform: Linux |
Afternoon,
I tried building 7.2.1 from the tar and am getting,
GRASS GIS 7.2.1 exported compilation log
Started compilation: Thu Jun 1 14:33:36 MST 2017
Errors in:
/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
So I did a `make` within that dir and get the following,
make /tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/etc/python/grass/lib
make[1]: Entering directory
'/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes'
make[1]: '/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/etc/python/grass/lib' is up to date.
make[1]: Leaving directory
make OBJ.x86_64-pc-linux-gnu/date.py OBJ.x86_64-pc-linux-gnu/gis.py
OBJ.x86_64-pc-linux-gnu/raster.py OBJ.x86_64-pc-linux-gnu/gmath.py
OBJ.x86_64-pc-linux-gnu/proj.py OBJ.x86_64-pc-linux-gnu/imagery.py
OBJ.x86_64-pc-linux-gnu/vector.py OBJ.x86_64-pc-linux-gnu/rtree.py
OBJ.x86_64-pc-linux-gnu/display.py OBJ.x86_64-pc-linux-gnu/stats.py
OBJ.x86_64-pc-linux-gnu/dbmi.py OBJ.x86_64-pc-linux-gnu/raster3d.py
OBJ.x86_64-pc-linux-gnu/arraystats.py OBJ.x86_64-pc-linux-gnu/cluster.py
OBJ.x86_64-pc-linux-gnu/vedit.py OBJ.x86_64-pc-linux-gnu/segment.py
OBJ.x86_64-pc-linux-gnu/rowio.py OBJ.x86_64-pc-linux-gnu/temporal.py
OBJ.x86_64-pc-linux-gnu/ogsf.py OBJ.x86_64-pc-linux-gnu/nviz.py
gnu/etc/python/grass/lib/date.py
gnu/etc/python/grass/lib/gis.py
gnu/etc/python/grass/lib/raster.py
gnu/etc/python/grass/lib/gmath.py
gnu/etc/python/grass/lib/proj.py
gnu/etc/python/grass/lib/imagery.py
gnu/etc/python/grass/lib/vector.py
gnu/etc/python/grass/lib/rtree.py
gnu/etc/python/grass/lib/display.py
gnu/etc/python/grass/lib/stats.py
gnu/etc/python/grass/lib/dbmi.py
gnu/etc/python/grass/lib/raster3d.py
gnu/etc/python/grass/lib/arraystats.py
gnu/etc/python/grass/lib/cluster.py
gnu/etc/python/grass/lib/vedit.py
gnu/etc/python/grass/lib/segment.py
gnu/etc/python/grass/lib/rowio.py
gnu/etc/python/grass/lib/temporal.py
gnu/etc/python/grass/lib/ogsf.py
gnu/etc/python/grass/lib/nviz.py
gnu/etc/python/grass/lib/__init__.py
gnu/etc/python/grass/lib/ctypes_preamble.py
gnu/etc/python/grass/lib/ctypes_loader.py
gnu/etc/python/grass/lib/date.pyc
gnu/etc/python/grass/lib/gis.pyc
gnu/etc/python/grass/lib/raster.pyc
gnu/etc/python/grass/lib/gmath.pyc
gnu/etc/python/grass/lib/proj.pyc
gnu/etc/python/grass/lib/imagery.pyc
gnu/etc/python/grass/lib/vector.pyc
gnu/etc/python/grass/lib/rtree.pyc
gnu/etc/python/grass/lib/display.pyc
gnu/etc/python/grass/lib/stats.pyc
gnu/etc/python/grass/lib/dbmi.pyc
gnu/etc/python/grass/lib/raster3d.pyc
gnu/etc/python/grass/lib/arraystats.pyc
gnu/etc/python/grass/lib/cluster.pyc
gnu/etc/python/grass/lib/vedit.pyc
gnu/etc/python/grass/lib/segment.pyc
gnu/etc/python/grass/lib/rowio.pyc
gnu/etc/python/grass/lib/temporal.pyc
gnu/etc/python/grass/lib/ogsf.pyc
gnu/etc/python/grass/lib/nviz.pyc
gnu/etc/python/grass/lib/__init__.pyc
gnu/etc/python/grass/lib/ctypes_preamble.pyc
gnu/etc/python/grass/lib/ctypes_loader.pyc
GISRC=/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/demolocation/.grassrc72
GISBASE=/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-gnu
PATH="/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/bin:/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/scripts:$PATH"
PYTHONPATH="/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/etc/python:/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/scripts:/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/lib:/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-
gnu/lib:.::/jre/lib" LC_ALL=C ./ctypesgen.py --cpp "gcc -E
-D_FORTIFY_SOURCE=2 -I/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64
-pc-linux-gnu/include -I/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-
linux-gnu/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_datetime.7.2.1
gnu/include/grass/datetime.h
gnu/include/grass/defs/datetime.h -o OBJ.x86_64-pc-linux-gnu/date.py
Status: Preprocessing /tmp/tmpfcx1LI.h
Status: gcc -E -D_FORTIFY_SOURCE=2
-I/tmp/makepkg/grass/src/grass-7.2.1/dist.x86_64-pc-linux-gnu/include
-D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
"-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
"-D__asm(x)=" "-DCTYPESGEN=1" /tmp/tmpfcx1LI.h
File "./ctypesgen.py", line 139, in <module>
descriptions = ctypesgencore.parser.parse(options.headers, options)
File
"/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/__init__.py",
line 22, in parse
parser.parse()
File
"/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py",
line 74, in parse
ctypesparser.CtypesParser.parse(self, fname, None)
File
"/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/cparser.py",
line 120, in parse
self.preprocessor_parser.parse(filename)
File
"/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/preprocessor.py",
line 218, in parse
token = self.lexer.token()
File
line 63, in token
result = lex.Lexer.token(self)
File
"/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/lex.py",
line 355, in token
newtok = func(tok)
File
"/tmp/makepkg/grass/src/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/pplexer.py",
line 262, in t_ANY_int
g1 = str(long(g1, 8))
ValueError: invalid literal for long() with base 8:
'08420217248550443400745280086994171'
make[1]: *** [Makefile:102: OBJ.x86_64-pc-linux-gnu/date.py] Error 1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3354>
