[GRASS-dev] [GRASS GIS] #3358: t.rast.what: null_value is insensitive to passed strings
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Keywords: t.rast.what | CPU: x86-64
Platform: Linux |
G7:t.rast.what has currently a parameter {{{null_value}}} that allows to
change the string representing NULL value (default is *). However, no
matter which string or number I use, with or without quotes, it only
outputs asteriks (*) where there are NULL values. It seems insensitive to
any string one passes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3358&gt;
Resolution: | Keywords: t.rast.what
       CPU: x86-64 | Platform: Linux
Comment (by veroandreo):
r71175 fixed the reported bug in G7:t.rast.what null_value option in
trunk. Thanks Soeren!
I leave the ticket open in case it needs to be backported
Ticket URL: <https://trac.osgeo.org/grass/ticket/3358#comment:1&gt;
Comment (by neteler):
Replying to [comment:1 veroandreo]:
I guess that this would require the backport of r71105 (t.rast.what: added
new r.what v flag; added test cases)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3358#comment:2&gt;
  Priority: normal | Milestone: 7.2.4
Comment (by lucadelu):
Do we want to backport this two changes (r71105 and r71175) to GRASS 7.2
branch otherwise we can close this ticket...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3358#comment:6&gt;
Milestone was 7.2 originally, but maybe it does not make sense at this
point. The fix is already in 74 and 76 relbranch
Ticket URL: <https://trac.osgeo.org/grass/ticket/3358#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: t.rast.what
Changes (by veroandreo):
* status: new => closed
* resolution: => fixed
Comment:
closing... reopen if you consider it should be backported
Ticket URL: <https://trac.osgeo.org/grass/ticket/3358#comment:8&gt;
  Priority: normal | Milestone: 7.4.2
Changes (by martinl):
* milestone: 7.2.4 => 7.4.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3358#comment:9&gt;
