#3361: v.select: very slow on within (GEOS) operator
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Keywords: v.select GEOS within slow | CPU: Unspecified
Platform: Unspecified |
I have not made similar tests with the other operators, but using the
within operator v.select is very slow.
First I create a buffer around the NC railroads map:
v.buffer railroads dist=5000 out=rail5000
Then v.select:
time v.select ain=boundary_municp bin=rail5000 op=within out=select
real 2m13.989s
user 1m57.888s
sys 0m15.956s
Using the following script, I get the identical result much faster (maybe
using v.distance is another option, but I haven't tried that):
g.copy vect=boundary_municp,munic
v.db.addcolumn munic col="totalarea double precision"
v.to.db munic op=area col=totalarea
v.overlay ain=munic bin=rail5000 op=and out=munic_and_buffer
v.db.addcolumn munic_and_buffer col="area double precision"
v.to.db munic_and_buffer op=area col=area
sleep 1
v.extract boundary_municp cat=$(db.select -c sql="select a_cat from
munic_and_buffer where round(area,1)/round(a_totalarea,1)=1" | awk
'{printf"%s,", $1}') output=select_bis
Time for running entire script:
real 0m14.611s
user 0m6.084s
sys 0m5.084s
I stumbled across this because a student had a within operation that kept
on running for hours and hours, and using an equivalent of the above
script we were able to get the same result within minutes.
I imagine that by going through GEOS we lose the spatial index, or that
there are other significant overheads, and that this is what causes such a
serious slowdown. This is such a difference, however, that I wonder if
there is anything we could do to optimize v.select's GEOS operators ? Or
is the only solution to implement the same operators natively ? Maybe a
nice GSoC project ?
I'm classifying this as an enhancement, but I'm pretty close to
considering such long operation time as soon as there is a significant
amount of data as a bug...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3361>
