[GRASS-dev] [GRASS GIS] #3363: Add mask input parameter to v.surf.idw
Reporter: Lads | Owner: grass-dev@…
Priority: normal | Milestone:
Component: Default | Version: 7.2.1
Keywords: | CPU: Unspecified
Platform: Unspecified |
It is not possible to use a mask with v.surf.idw. The r.mask module only
applies when reading data from disk and therefore has no effect on the
interpolation area, which is always set to the entire region. This creates
an unnecessary computation overhead when the desired area to interpolate
does not cover the entire region.
The v.surf.rst module already has an input parameter for this purpose
(called mask). The goal would be for v.surf.idw to provide a similar
parameter.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3363&gt;
Component: Vector | Version: 7.2.1
Resolution: | Keywords: v.surf.idw, mask
Changes (by annakrat):
* keywords: => v.surf.idw, mask
* component: Default => Vector
Ticket URL: <https://trac.osgeo.org/grass/ticket/3363#comment:1&gt;
  Priority: normal | Milestone: 7.8.0
Changes (by sbl):
* milestone: 7.2.4 => 7.8.0
Comment:
All enhancements should point to 7.8
Ticket URL: <https://trac.osgeo.org/grass/ticket/3363#comment:3&gt;
