#3365: r.in.gdal: crash on large dataset
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Raster | Version: svn-releasebranch72
Resolution: | Keywords: r.in.gdal
CPU: x86-64 | Platform: Linux
Old description:
Trying to import a large VRT dataset, I get a crash:
GRASS 7.2.2svn (latlong):~/software/grass72_svn_debugmode/bin.x86_64-pc-
linux-gnu > r.in.gdal
input=/mnt/kvm7-storage/geodata/global_forest/GFC-2015-v1.3/loss_global_forest_cover_loss_2000_2015/loss_global_forest_cover_loss_2000_2015.vrt
output=loss_global_forest_cover_loss_2000_2015
Proceeding with import of 1 raster bands...
Importing raster map <loss_global_forest_cover_loss_2000_2015>...
Segmentation fault (core dumped)
Debugging:
linux-gnu > gdb r.in.gdal
GNU gdb (GDB) Fedora 7.12.1-48.fc25
Copyright (C) 2017 Free Software Foundation, Inc.
Reading symbols from r.in.gdal...done.
(gdb) r
input=/mnt//GFC-2015-v1.3/loss_global_forest_cover_loss_2000_2015.vrt
Starting program:
/home/mundialis/software/grass72_svn_debugmode/dist.x86_64-pc-linux-
gnu/bin/r.in.gdal
Missing separate debuginfos, use: dnf debuginfo-install
glibc-2.24-8.fc25.x86_64
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff77a1ab9 in put_data (fd=0, null_buf=0x7fffffe9b020 "",
cell=0x7fffc62ac010, row=0, n=1440000, zeros_r_nulls=0) at put_row.c:370
370 compressed_buf[0] = work_buf[0] = nbytes;
(gdb) bt full
#0 0x00007ffff77a1ab9 in put_data (fd=0, null_buf=0x7fffffe9b020 "",
wk = 0x7fffff91cb31 ""
nbytes = 1
compressed_buf = 0x7fffff7bd220 <error: Cannot access memory at
address 0x7fffff7bd220>
total = 1440000
fcb = 0x691080
compressed = 1
len = 4
work_buf = 0x7fffff91cb30 "\001"
nwrite = 0
#1 0x00007ffff77a1f98 in put_raster_data (fd=0, null_buf=0x7fffffe9b020
"", rast=0x7fffc62ac010, row=0, n=1440000, zeros_r_nulls=0, map_type=0)
at put_row.c:476
fcb = 0x691080
#2 0x00007ffff77a2bdb in put_raster_row (fd=0, buf=0x7fffc62ac010,
data_type=0, zeros_r_nulls=0) at put_row.c:699
convert_and_write_FtypeOtype = {{0x0, 0x7ffff77a23d9
<convert_and_write_if>, 0x7ffff77a25f5 <convert_and_write_id>}, {
0x7ffff77a280f <convert_and_write_fi>, 0x0, 0x7ffff77a26f3
<convert_and_write_fd>}, {0x7ffff77a2928 <convert_and_write_di>,
0x7ffff77a24d7 <convert_and_write_df>, 0x0}}
fcb = 0x691080
null_buf = 0x7fffffe9b020 ""
#3 0x00007ffff77a0f8b in Rast_put_row (fd=0, buf=0x7fffc62ac010,
data_type=0) at put_row.c:67
No locals.
#4 0x0000000000406e4d in ImportBand (hBand=0x7dbcb0, output=0x627dc0
"loss_global_forest_cover_loss_2000_2015", group_ref=0x0) at main.c:1141
data_type = 0
eGDT = GDT_Int32
eRawGDT = GDT_Byte
row = 1
nrows = 560000
ncols = 1440000
complex = 0
cf = 0
cfR = 32767
cfI = -145625496
bNoDataEnabled = 0
indx = 32767
cell = 0x7fffc62ac010
cellReal = 0x77
cellImg = 0x7fffffffac40
bufComplex = 0x7fffffffab40
dfNoData = -10000
outputReal =
"0\341\377\367\377\177\000\000\260\254\377\377\377\177\000\000\071\031@\000\000\000\000\000\243\366\251\242\000\000\000\000\377\377\377\377",
'\000' <repeats 12 times>,
"H\017\064\366\377\177\000\000\000\240\374\367\377\177\000\000\000\000\000\000\000\000\360?",
'\000' <repeats 14 times>, "\360?", '\000' <repeats 30 times>,
"\360?\000\000\000\000\000\000\000\000\220\062@\000\000\000\000\000\314\345w\367\377\177\000\000P\255\377\377\377\177\000\000\350\262`\000\000\000\000\000\220\062@\000\000\000\000\000\320\332\377\377\377\177",
'\000' <repeats 18 times>, "\360\331\377\377\377\177\000\000"...
outputImg = '\000' <repeats 32 times>,
"\377\000\000\000\000\000\377\377\000\000\000\000\000\000\377\377\000\000\000\000\000\000\377\377\377\377\377\377\000\377\377\377",
'\000' <repeats 22 times>, "\360?", '\000' <repeats 14 times>, "\360?",
"\360?\000\000\000\000\000\000\000\000\210\345w\367\377\177", '\000'
<repeats 26 times>,
"\001\000\000\000\000\000\000\000\001\000\000\000\000\000\000\000\200\256\377\377\377\177\000\000\240\224z\367\377\177\000\000\000\273}",
'\000' <repeats 13 times>...
nullFlags = 0x0
history = {fields = {0x7ffff7fca000 "", 0x7fffffffabe8 "",
0x7fffffffabe4 "", 0x7ffff7ff7b78 "\350\343\377\367\377\177",
0x7fffffffaba0 "\300\254\377\377\377\177", 0x401939
"GDALGetRasterBand", 0x400be8 "\261\a", 0x7fffffffabe8 ""}, nlines =
-1565919581,
lines = 0x28aa7da}
GDALmetadata = 0x7ffff77aa094
have_colors = 0
gdal_rat = 0x7ffff752f25f <find_file1+198>
#5 0x0000000000405231 in main (argc=3, argv=0x7fffffffdad8) at
main.c:619
nBand = 1
input = 0x627d20
"/mnt/GFC-2015-v1.3/loss_global_forest_cover_loss_2000_2015.vrt"
output = 0x627dc0 "loss_global_forest_cover_loss_2000_2015"
title = 0x0
cellhd = {format = 0, compressed = 0, rows = 560000, rows3 =
560000, cols = 1440000, cols3 = 1440000, depths = 1, proj = 3, zone = 0,
ew_res = 0.00025000000000000017, ew_res3 =
0.00025000000000000017, ns_res = 0.00025000000000000017, ns_res3 =
0.00025000000000000017, tb_res = 1,
north = 80, south = -60.000000000000085, east =
180.00000000000023, west = -180, top = 1, bottom = 0}
loc_wind = {format = 0, compressed = -1, rows = 1, rows3 = 1,
cols = 1, cols3 = 1, depths = 1, proj = 3, zone = 0, ew_res = 1, ew_res3
= 1,
ns_res = 1, ns_res3 = 1, tb_res = 1, north = 1, south = 0, east
= 1, west = 0, top = 1, bottom = 0}
cur_wind = {format = 0, compressed = 0, rows = 0, rows3 = 0, cols
= 0, cols3 = 0, depths = 0, proj = 0, zone = 0, ew_res = 0, ew_res3 = 0,
ns_res = 0, ns_res3 = 0, tb_res = 0, north = 0, south = 0, east
= 0, west = 0, top = 0, bottom = 0}
proj_info = 0x68ced0
proj_units = 0x68cbf0
loc_proj_info = 0x68e5f0
loc_proj_units = 0x7db4f0
hDS = 0x7dbb00
hDriver = 0x62ef90
hBand = 0x7dbcb0
adfGeoTransform = {-180, 0.00025000000000000017, 0, 80, 0,
-0.00025000000000000017}
n_bands = 0
force_imagery = 0
error_msg = "\253\000\000\000\022", '\000' <repeats 19 times>,
"i\000\000\000\022", '\000' <repeats 19 times>, "\222\000\000\000\022",
'\000' <repeats 19 times>, "\231\000\000\000\022", '\000' <repeats 19
times>, "\001\000\000\000
\000\000\000@\323\377\377\377\177\000\000\260\327\377\377\377\177\000\000\350
Y\372\367\377\177\000\000\060U\372\367\377\177\000\000\001\000\000\000\000\000\000\000\235\066\313\335\377\177\000\000\260Q\336\367\377\177\000\000\000\000\000\000\000\000\000\000D|\336\367\377\177\000\000`O\372\367\377\177\000\000\210\337\377\367\377\177\000\000\000\000\000\000\000\000\000\000"...
projcomp_error = 1
overwrite = 0
offset = 0
suffix = 0x629130 ""
num_digits = 0
module = 0x7ffff777ea28 <state+40>
parm = {input = 0x7ffff777ea88 <state+136>, output = 0x626ea0,
target = 0x6270e0, title = 0x6271a0, outloc = 0x6274a0, band = 0x626f60,
memory = 0x627020, offset = 0x627260, num_digits = 0x627320,
map_names_file = 0x6273e0, rat = 0x627560}
flag_o = 0x7ffff777ea58 <state+88>
flag_e = 0x626840
flag_k = 0x627ab0
flag_f = 0x627a10
flag_l = 0x627a60
flag_c = 0x627b00
flag_p = 0x627b50
flag_j = 0x626550
(gdb)
Doing a convert operation with GDAL, no apparent issues (I CTRL-C'd it
then):
gdal_translate
/mnt/geodata/global_forest/GFC-2015-v1.3/loss_global_forest_cover_loss_2000_2015/loss_global_forest_cover_loss_2000_2015.vrt
/scratch/bla.tif
Input file size is 1440000, 560000
0..
**Data source:**
http://earthenginepartners.appspot.com/science-2013-global-
forest/download_v1.3.html
I created a VRT from the "loss" layer tiles which I then tried to import
as above:
gdalbuildvrt loss_global_forest_cover_loss_2000_2015.vrt *.tif
gdalinfo loss_global_forest_cover_loss_2000_2015.vrt
Driver: VRT/Virtual Raster
Size is 1440000, 560000
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,80.000000000000000)
Pixel Size = (0.000250000000000,-0.000250000000000)
Corner Coordinates:
Upper Left (-180.0000000, 80.0000000) (180d 0' 0.00"W, 80d 0' 0.00"N)
Lower Left (-180.0000000, -60.0000000) (180d 0' 0.00"W, 60d 0' 0.00"S)
Upper Right ( 180.0000000, 80.0000000) (180d 0' 0.00"E, 80d 0' 0.00"N)
Lower Right ( 180.0000000, -60.0000000) (180d 0' 0.00"E, 60d 0' 0.00"S)
Center ( 0.0000000, 10.0000000) ( 0d 0' 0.00"E, 10d 0' 0.00"N)
Band 1 Block=128x128 Type=Byte, ColorInterp=Gray
Test with GRASS GIS 7.3:
GRASS 7.3.svn (latlong):~/software/grass73_svn > r.in.gdal
input=/mnt/geodata/global_forest/GFC-2015-v1.3/loss_global_forest_cover_loss_2000_2015/loss_global_forest_cover_loss_2000_2015.vrt
0% Segmentation fault (core dumped)
System:
gcc -v
gcc version 6.3.1 20161221 (Red Hat 6.3.1-1) (GCC)
uname -a
Linux fedora-calc 4.9.12-200.fc25.x86_64 #1 SMP Thu Feb 23 19:31:49 UTC
2017 x86_64 x86_64 x86_64 GNU/Linux
New description:
Debugging:
(gdb) r
Starting program:
gnu/bin/r.in.gdal
(gdb) bt full
nbytes = 1
total = 1440000
fcb = 0x691080
compressed = 1
len = 4
nwrite = 0
at put_row.c:476
fcb = 0x691080
fcb = 0x691080
No locals.
data_type = 0
eGDT = GDT_Int32
eRawGDT = GDT_Byte
row = 1
nrows = 560000
ncols = 1440000
complex = 0
cf = 0
cfR = 32767
cfI = -145625496
bNoDataEnabled = 0
indx = 32767
cellReal = 0x77
dfNoData = -10000
outputReal =
<repeats 26 times>,
nullFlags = 0x0
-1565919581,
lines = 0x28aa7da}
have_colors = 0
#5 0x0000000000405231 in main (argc=3, argv=0x7fffffffdad8) at main.c:619
nBand = 1
input = 0x627d20
title = 0x0
loc_wind = {format = 0, compressed = -1, rows = 1, rows3 = 1, cols
= 1, cols3 = 1, depths = 1, proj = 3, zone = 0, ew_res = 1, ew_res3 = 1,
hDS = 0x7dbb00
hDriver = 0x62ef90
hBand = 0x7dbcb0
n_bands = 0
force_imagery = 0
projcomp_error = 1
overwrite = 0
offset = 0
num_digits = 0
flag_e = 0x626840
flag_k = 0x627ab0
flag_f = 0x627a10
flag_l = 0x627a60
flag_c = 0x627b00
flag_p = 0x627b50
flag_j = 0x626550
(gdb)
then):
gdal_translate
/scratch/bla.tif
0..
**Data source:**
as above:
GEOGCS["WGS 84",
DATUM["WGS_1984",
Corner Coordinates:
System:
gcc -v
uname -a
Comment (by neteler):
Using valgrind:
GRASS 7.3.svn (latlong):~ > valgrind $CMD
==30211== Memcheck, a memory error detector
==30211== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==30211== Using Valgrind-3.12.0 and LibVEX; rerun with -h for copyright
info
==30211== Command: r.in.gdal
input=/mnt/GFC-2015-v1.3/loss_global_forest_cover_loss_2000_2015/loss_global_forest_cover_loss_2000_2015.vrt
==30211==
==30211== Warning: client switching stacks? SP change: 0xffee9d140 -->
0xffe91ed30
==30211== to suppress, use: --max-stackframe=5760016 or greater
==30211== Invalid write of size 8
==30211== at 0x5273D89: ??? (in
/home/mundialis/software/grass73_svn/dist.x86_64-pc-linux-
gnu/lib/libgrass_raster.7.3.svn.so)
==30211== by 0x52744B4: ??? (in
==30211== by 0x4063DE: ??? (in
gnu/bin/r.in.gdal)
==30211== by 0x404F64: main (in
gnu/bin/r.in.gdal)
==30211== Address 0xffe91ed28 is on thread 1's stack
==30211==
==30211== Invalid read of size 8
==30211== at 0x6D63E3F: lseek (in /usr/lib64/libc-2.24.so)
==30211== by 0x5273D8D: ??? (in
gnu/bin/r.in.gdal)
gnu/bin/r.in.gdal)
==30211== in frame #0, created by lseek (???
==30211==
==30211== Invalid write of size 1
==30211== at 0x527378C: ??? (in
gnu/bin/r.in.gdal)
gnu/bin/r.in.gdal)
==30211== Address 0xffe91ed34 is on thread 1's stack
==30211==
==30211== at 0x5273798: ??? (in
gnu/bin/r.in.gdal)
gnu/bin/r.in.gdal)
==30211== Address 0xffe91ed32 is on thread 1's stack
==30211==
==30211== Invalid read of size 1
==30211== at 0x527384E: ??? (in
gnu/bin/r.in.gdal)
gnu/bin/r.in.gdal)
==30211== Address 0xffe91ed31 is on thread 1's stack
==30211==
==30211==
==30211== More than 10000000 total errors detected. I'm not reporting any
more.
==30211== Final error counts will be inaccurate. Go fix your program!
==30211== Rerun with --error-limit=no to disable this cutoff. Note
==30211== that errors may occur in your program without prior warning from
==30211== Valgrind, because errors are no longer being displayed.
==30211==
==30211==
==30211== Process terminating with default action of signal 11 (SIGSEGV):
dumping core
==30211== Access not within mapped region at address 0xFFE7BF420
==30211== at 0x5273CBA: ??? (in
==30211== If you believe this happened as a result of a stack
==30211== overflow in your program's main thread (unlikely but
==30211== possible), you can try to increase the size of the
==30211== main thread stack using the --main-stacksize= flag.
==30211== The main thread stack size used in this run was 8388608.
==30211==
==30211== Access not within mapped region at address 0xFFE7BF418
==30211== at 0x4A286C0: _vgnU_freeres (vg_preloaded.c:59)
==30211==
==30211== HEAP SUMMARY:
==30211== in use at exit: 106,603,369 bytes in 11,066 blocks
==30211== total heap usage: 78,802 allocs, 67,736 frees, 136,593,845
bytes allocated
==30211==
==30211== LEAK SUMMARY:
==30211== definitely lost: 134 bytes in 5 blocks
==30211== indirectly lost: 353 bytes in 20 blocks
==30211== possibly lost: 0 bytes in 0 blocks
==30211== still reachable: 106,602,882 bytes in 11,041 blocks
==30211== suppressed: 0 bytes in 0 blocks
==30211== Rerun with --leak-check=full to see details of leaked memory
==30211==
==30211== For counts of detected and suppressed errors, rerun with: -v
==30211== ERROR SUMMARY: 10000000 errors from 5 contexts (suppressed: 0
from 0)
Next I converted the VRT to GeoTIFF and tried to import that:
GRASS 7.3.svn (latlong):~ > nice gdal_translate -co "COMPRESS=DEFLATE"
/mnt/global_forest/GFC-2015-v1.3/loss_global_forest_cover_loss_2000_2015/loss_global_forest_cover_loss_2000_2015.vrt
/scratch/loss_global_forest_cover_loss_2000_2015.tif
0..10...20...30...40...50...60...70...80...90...100 - done.
GRASS 7.3.svn (latlong):~ > r.in.gdal
out=loss_global_forest_cover_loss_2000_2015
The debug results are the same as before:
r GNU gdb (GDB) Fedora 7.12.1-48.fc25
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>\.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>\.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
(gdb) r /scratch/loss_global_forest_cover_loss_2000_2015.tif
Starting program:
gnu/bin/r.in.gdal /scratch/loss_global_forest_cover_loss_2000_2015.tif
0x00007ffff77a1ab9 in put_data (fd=0, null_buf=0x7fffffe9b080 "",
cell=0x7fffc57fd010, row=0, n=1440000, zeros_r_nulls=0) at put_row.c:370
Ticket URL: <https://trac.osgeo.org/grass/ticket/3365#comment:2>
