GDAL
July 6, 2017, 1:03pm
1
#3367: g.gui.animation: animated GIF export generates corrupted GIF files
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: wxGUI | Version: unspecified
Keywords: g.gui.animation | CPU: Unspecified
Platform: Unspecified |
When exporting an animated GIF, the generated file is corrupted:
# using GRASS 7.2.2svn (nc_climate_spm_2000_2012): >
g.region raster=2002_10_precip -p
g.gui.animation `g.list raster pattern="2*_10_precip" sep=comma`
Default TGIS driver / database set to:
driver: sqlite
database: $GISDBASE/$LOCATION_NAME/$MAPSET/tgis/sqlite.db
WARNING: Temporal database connection defined as:
/home/mneteler/grassdata/nc_climate_spm_2000_2012/climate_1970_2012/tgis/sqlite.db
But database file does not exist.
Creating temporal database:
/home/mneteler/software/grass72/dist.x86_64-pc-linux-
gnu/etc/python/grass/imaging/images2gif.py:344: VisibleDeprecationWarning:
converting an array with ndim > 0 to an index will result in an error in
the future
im2 = im[y0:y1, x0:x1]
(not sure if the warning matters)
-rw-r--r-- 1 mneteler mneteler 1561325 Jul 6 14:55 bla.gif
display: corrupt image `bla.gif' @ error/gif.c/ReadGIFImage/1368.
System:
System Info
GRASS version: 7.2.2svn
GRASS SVN revision: r71233M
Build date: 2017-07-03
Build platform: x86_64-pc-linux-gnu
GDAL: 2.1.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.14.2
Python: 2.7.13
wxPython: 3.0.2.0
Platform: Linux-4.11.3-202.fc25.x86_64-x86_64-with-fedora-25-Twenty_Five
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
July 6, 2017, 1:04pm
2
Component: wxGUI | Version: svn-releasebranch72
Resolution: | Keywords: g.gui.animation
CPU: x86-64 | Platform: Linux
Changes (by neteler):
* platform: Unspecified => Linux
* version: unspecified => svn-releasebranch72
* cpu: Unspecified => x86-64
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:1> ;
GDAL
July 8, 2017, 1:36pm
3
Type: defect | Status: closed
Resolution: fixed | Keywords: g.gui.animation
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"71243" 71243]:
#!CommitTicketReference repository="" revision="71243"
pythonlib: fix #3367 - creating gif files
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:2> ;
GDAL
July 8, 2017, 1:38pm
4
Type: defect | Status: reopened
* status: closed => reopened
* resolution: fixed =>
Comment:
It automatically closed it, please test and I will backport it then.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:3> ;
GDAL
July 8, 2017, 2:44pm
5
Comment (by veroandreo):
Replying to [comment:3 annakrat]:
After updating (make distclean ; svn up && sh config_grass7.sh && make), I
still get a corrupted gif from g.gui.animation.
display: corrupt image `prueba.gif' @ error/gif.c/ReadGIFImage/1368.
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r71243M
Build date: 2017-07-08
GDAL: 2.1.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.14.2
Python: 2.7.13
wxPython: 3.0.2.0
Platform: Linux-4.11.8-200.fc25.x86_64-x86_64-with-fedora-25-Twenty_Five
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:4> ;
GDAL
July 8, 2017, 6:47pm
6
Comment (by hellik):
tested here with
GDAL: 2.2.0
PROJ.4: 4.9.3
GEOS: 3.5.1
SQLite: 3.16.2
Python: 2.7.13
wxPython: 3.0.2.0
Platform: Linux-4.9.0-3-amd64-x86_64-with-debian-9.0
display-im6.q16: corrupt image `gguitest2.gif' @
error/gif.c/ReadGIFImage/1386.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:5> ;
GDAL
July 9, 2017, 1:03am
7
Comment (by annakrat):
My gifs are ok... Could you test this code snippet to see if the problem
is in the images2gif (likely)? Also do you have Pillow or PIL?
import os
from PIL import Image
from grass.imaging import writeGif
color_path = os.path.join(os.environ['GISBASE'], "docs", "html",
"colortables")
pil_images = [Image.open(os.path.join(color_path, c)) for c in
os.listdir(color_path)]
writeGif('/tmp/test.gif', pil_images, duration=0.2, repeat=True)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:6> ;
GDAL
July 9, 2017, 7:32am
8
Replying to [comment:6 annakrat]:
> import os
"colortables")
lines above tested
display-im6.q16: corrupt image `test.gif' @ error/gif.c/ReadGIFImage/1386.
the same error
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:7> ;
GDAL
July 9, 2017, 7:39am
9
python-pil 4.0.0-4
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:8> ;
GDAL
July 9, 2017, 7:58am
10
I tested the code in the python console of GRASS GUI. The output gif gives
the same error as before.
I have python2-pillow-3.4.2-1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:9> ;
GDAL
July 9, 2017, 9:28pm
11
Could you test any of the available versions of images2gif.py files from
different repositories? I found couple for example:
https://bitbucket.org/bench/images2gif.py/raw/a618bd8fc352f278a3b0c777cb6427ec39236f0a/images2gif.py
https://github.com/isaacgerg/images2gif/blob/master/images2gif.py
https://gist.github.com/jonschoning/7216290
https://github.com/rec/echomesh/blob/master/code/python/external/images2gif.py
If you replace the import with
{{{ from images2gif import writeGif}}}
then the test code snippet should work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:10> ;
GDAL
July 10, 2017, 8:32am
12
Replying to [comment:10 annakrat]:
tested here with
System Info
GRASS SVN revision: r71251
Build date: 2017-07-09
Build platform: x86_64-w64-mingw32
GDAL: 2.2.1
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
and no change in images2gif.
the gif is exported, but it's not displayed correctly. only the first
frame is shown and the next frames are white
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:11> ;
GDAL
July 10, 2017, 8:53am
13
tested here on windows all these images2gif.py, none of them worked.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:12> ;
GDAL
July 10, 2017, 2:25pm
14
I tested it on standalone winGRASS and OSGEO4W and it works in the
standalone one, but not in OSGEO4W. It seems they use different PIL
library, so that must be the difference. I will look into it later.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:13> ;
GDAL
July 12, 2017, 3:33am
15
In [changeset:"71258" 71258]:
#!CommitTicketReference repository="" revision="71258"
pythonlib: add PIL native implementation available since Pillow 3.4.0, see
#3367
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:14> ;
GDAL
July 12, 2017, 3:43am
16
So, after some digging around, it seems to stop working since Pillow
version 3.4.0 and I haven't found anywhere a working version of
images2gif.py and I haven't been able to find the problem. But since 3.4.0
Pillow itself allows to write GIFs, so I added it there. Now depending on
your PIL/Pillow and Pillow version, either the old or the native Pillow
way is used. The problem is the GIF created by Pillow looks worse, but I
don't know what could be done here.
Also we could use imagemagick as a backend if it's installed and
available.
Anyway, please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:15> ;
GDAL
July 12, 2017, 6:44am
17
Tested here having python2-pillow-3.4.2-1. Now, it works, but as you say
the GIF doesn't look so good in terms of definition of the images. They
look noisy, as when you increase ISO in the camera.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:16> ;
GDAL
September 8, 2017, 12:45pm
18
Comment (by martinl):
Replying to [comment:16 veroandreo]:
I can confirm it. I have `python-pil 4.2.1-1`. See attachment:noisy.gif
created by
import os
"colortables")
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:17> ;
GDAL
September 8, 2017, 12:46pm
19
Changes (by martinl):
* Attachment "noisy.gif" added.
GDAL
September 8, 2017, 12:51pm
20
In [changeset:"71481" 71481]:
#!CommitTicketReference repository="" revision="71481"
pythonlib: see #3367 - creating gif files (merge r71243 from trunk)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:18> ;
