[GRASS-dev] [GRASS GIS] #3368: warnings and errors in compilation log
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Compiling | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: All |
looking into the
[https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71243-290/
package.log] regarding warnings and errors during compilations in windows
(zipped log file attached), there are some warnings and error (AFAIR I've
seen them also in my debian 9):
e.g.
make[3]: Leaving directory '/c/msys64/usr/src/grass_trunk/lib/display'
make[3]: Entering directory '/c/msys64/usr/src/grass_trunk/lib/db'
make -C dbmi_base || echo /c/msys64/usr/src/grass_trunk/lib/db/dbmi_base
>> /c/msys64/usr/src/grass_trunk/error.log
make[4]: Entering directory
'/c/msys64/usr/src/grass_trunk/lib/db/dbmi_base'
test -d OBJ.x86_64-w64-mingw32 || mkdir -p OBJ.x86_64-w64-mingw32
gcc -I/c/OSGeo4W64/include -g -O2 -I/c/OSGeo4W64/include
-I/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\"
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/alloc.o -c alloc.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/case.o -c case.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/column.o -c
column.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/columnfmt.o -c
columnfmt.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/connect.o -c
connect.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/cursor.o -c
cursor.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/datetime.o -c
datetime.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/dbmscap.o -c
dbmscap.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/default_name.o -c
default_name.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/dirent.o -c
dirent.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/error.o -c error.c
error.c: In function 'db_noproc_error':
error.c:159:6: warning: type of 'procnum' defaults to 'int' [-Wimplicit-
int]
  void db_noproc_error(procnum)
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/handle.o -c
handle.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/index.o -c index.c
-DRELDIR=\"lib/db/dbmi_base\" -o OBJ.x86_64-w64-mingw32/interval.o -c
interval.c
exec.c: In function 'exec_rectify':
exec.c:61:11: warning: passing argument 1 of 'time' from incompatible
pointer type [-Wincompatible-pointer-types]
       time(&start_time);
In file included from exec.c:14:0:
C:/msys64/mingw64/x86_64-w64-mingw32/include/time.h:212:29: note: expected
'time_t * {aka long long int *}' but argument is of type 'long int *'
  __CRT_INLINE time_t __cdecl time(time_t *_Time) { return _time64(_Time);
exec.c:80:8: warning: passing argument 1 of 'time' from incompatible
    time(&rectify_time);
make -C i.aster.toar || echo
/c/msys64/usr/src/grass_trunk/imagery/i.aster.toar >>
'/c/msys64/usr/src/grass_trunk/imagery/i.aster.toar'
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
-DRELDIR=\"imagery/i.aster.toar\" -o OBJ.x86_64-w64-mingw32/gain_aster.o
-c gain_aster.c
-DRELDIR=\"imagery/i.aster.toar\" -o OBJ.x86_64-w64-mingw32/main.o -c
main.c
main.c: In function 'main':
main.c:314:9: warning: iteration 14u invokes undefined behavior
[-Waggressive-loop-optimizations]
          Rast_close(infd[i]);
main.c:312:5: note: containing loop
      for (i = 1; i <= MAXFILES; i++) {
main.c:310:13: warning: iteration 14u invokes undefined behavior
              Rast_put_row(outfd[i], outrast[i - 1], out_data_type);
main.c:309:9: note: containing loop
main.c:280:13: warning: iteration 14u invokes undefined behavior
              Rast_get_row(infd[i], inrast[i - 1], row, in_data_type[i -
1]);
main.c:279:9: note: containing loop
export_areas.c: In function 'export_areas_multi':
export_areas.c:199:13: warning: ignoring return value of
'OGR_L_CreateFeature', declared with attribute warn_unused_result
[-Wunused-result]
              OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
export_areas.c:248:9: warning: ignoring return value of
[-Wunused-result]
export_areas.c: In function 'export_areas_single':
export_areas.c:101:13: warning: ignoring return value of
[-Wunused-result]
-D_FILE_OFFSET_BITS=64 -I/c/OSGeo4W64/include -I/c/OSGeo4W64/include
-DPACKAGE=\""grassmods"\" -I/c/OSGeo4W64/include
-DRELDIR=\"vector/v.out.ogr\" -o OBJ.x86_64-w64-mingw32/export_lines.o -c
export_lines.c
export_lines.c: In function 'export_lines_multi':
export_lines.c:228:13: warning: ignoring return value of
[-Wunused-result]
export_lines.c:275:9: warning: ignoring return value of
[-Wunused-result]
export_lines.c: In function 'export_lines_single':
export_lines.c:135:13: warning: ignoring return value of
[-Wunused-result]
-DRELDIR=\"vector/v.out.ogr\" -o OBJ.x86_64-w64-mingw32/list.o -c list.c
-DRELDIR=\"vector/v.out.ogr\" -o OBJ.x86_64-w64-mingw32/main.o -c main.c
main.c:714:2: warning: ignoring return value of 'OGR_L_StartTransaction',
declared with attribute warn_unused_result [-Wunused-result]
   OGR_L_StartTransaction(Ogr_layer);
main.c:760:2: warning: ignoring return value of 'OGR_L_CommitTransaction',
   OGR_L_CommitTransaction(Ogr_layer);
make -C v.surf.rst || echo /c/msys64/usr/src/grass_trunk/vector/v.surf.rst
'/c/msys64/usr/src/grass_trunk/vector/v.surf.rst'
-DRELDIR=\"vector/v.surf.rst\" -o OBJ.x86_64-w64-mingw32/main.o -c main.c
main.c:642:31: warning: passing argument 41 of 'IL_init_params_2d' from
incompatible pointer type [-Wincompatible-pointer-types]
          Tmp_fd_yy, Tmp_fd_xy, devi, NULL, cv,
In file included from main.c:40:0:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/interpf.h:115:6:
note: expected 'FILE * {aka struct _iobuf *}' but argument is of type
'char *'
  void IL_init_params_2d(struct interp_params *, FILE *, int, int, double,
make -C v.lrs.where || echo
/c/msys64/usr/src/grass_trunk/vector/v.lrs/v.lrs.where >>
'/c/msys64/usr/src/grass_trunk/vector/v.lrs/v.lrs.where'
-DRELDIR=\"vector/v.lrs/v.lrs.where\" -o OBJ.x86_64-w64-mingw32/main.o -c
main.c
main.c:88:24: warning: assignment discards 'const' qualifier from pointer
target type [-Wdiscarded-qualifiers]
      driver_opt->answer = db_get_default_driver_name();
main.c:95:26: warning: assignment discards 'const' qualifier from pointer
      database_opt->answer = db_get_default_database_name();
'/c/msys64/usr/src/grass_trunk/vector/v.lrs/v.lrs.label'
-DRELDIR=\"vector/v.lrs/v.lrs.label\" -o OBJ.x86_64-w64-mingw32/main.o -c
main.c
main.c:126:24: warning: assignment discards 'const' qualifier from pointer
main.c:133:26: warning: assignment discards 'const' qualifier from pointer
'/c/msys64/usr/src/grass_trunk/vector/v.generalize'
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/displacement.o
-c displacement.c
In file included from displacement.c:25:0:
point.h:74:22: warning: inline function 'point_dist_segment_square'
declared but never defined
  extern inline double point_dist_segment_square(POINT a, POINT b, POINT c,
point.h:71:22: warning: inline function 'point_angle_between' declared but
never defined
  extern inline double point_angle_between(POINT a, POINT b, POINT c);
point.h:68:22: warning: inline function 'point_dist_square' declared but
never defined
  extern inline double point_dist_square(POINT a, POINT b);
point.h:65:22: warning: inline function 'point_dist' declared but never
defined
  extern inline double point_dist(POINT a, POINT b);
point.h:62:20: warning: inline function 'points_copy_last' declared but
never defined
  extern inline void points_copy_last(struct line_pnts *Points, int pos);
point.h:59:20: warning: inline function 'point_scalar' declared but never
defined
  extern inline void point_scalar(POINT a, double k, POINT * res);
point.h:51:20: warning: inline function 'point_assign' declared but never
defined
  extern inline void point_assign(struct line_pnts *Points, int index,
point.h:46:22: warning: inline function 'point_dist2' declared but never
defined
  extern inline double point_dist2(POINT a);
point.h:40:20: warning: inline function 'point_add' declared but never
defined
  extern inline void point_add(POINT a, POINT b, POINT * res);
point.h:37:20: warning: inline function 'point_subtract' declared but
never defined
  extern inline void point_subtract(POINT a, POINT b, POINT * res);
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/main.o -c
main.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/matrix.o -c
matrix.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/misc.o -c
misc.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/network.o -c
network.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/point.o -c
point.c
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/pq.o -c pq.c
OBJ.x86_64-w64-mingw32/simplification.o -c simplification.c
In file included from simplification.c:24:0:
never defined
never defined
defined
never defined
defined
defined
defined
defined
never defined
-DRELDIR=\"vector/v.generalize\" -o OBJ.x86_64-w64-mingw32/smoothing.o -c
smoothing.c
In file included from smoothing.c:25:0:
never defined
never defined
defined
never defined
defined
defined
defined
defined
never defined
'/c/msys64/usr/src/grass_trunk/raster3d/r3.retile'
-DRELDIR=\"raster3d/r3.retile\" -o OBJ.x86_64-w64-mingw32/main.o -c main.c
main.c:110:12: warning: assignment discards 'const' qualifier from pointer
      mapset = G_find_raster3d(param.input->answer, "");
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/iostream/empq_adaptive_impl.h:47:0,
                  from
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/iostream/ami.h:58,
                  from visibility.h:42,
                  from viewshed.h:42,
                  from viewshed.cpp:48:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/iostream/empq_adaptive.h:
In constructor 'EMPQueueAdaptive<T, Key>::EMPQueueAdaptive(long int)':
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/iostream/empq_adaptive.h:69:47:
warning: delegating constructors only available with -std=c++11 or
-std=gnu++11
    EMPQueueAdaptive(long N) : EMPQueueAdaptive() {};
viewshed.cpp: In function 'AEvent* allocate_eventlist(GridHeader*)':
viewshed.cpp:154:59: warning: left shift count >= width of type [-Wshift-
count-overflow]
   long long maxsizet = ((long long)1 << (sizeof(size_t) * 8)) - 1;
c++ -I/c/OSGeo4W64/include -g -O2 -I/c/OSGeo4W64/include
-D_FILE_OFFSET_BITS=64 -DUSER=\"\" -Wno-sign-compare
-DRELDIR=\"raster/r.viewshed\" -o OBJ.x86_64-w64-mingw32/visibility.o -c
visibility.cpp
                  from
                  from visibility.cpp:46:
-std=gnu++11
-std=gnu++11
main.cpp: In function 'void parse_args(int, char**, int*, int*,
ViewOptions*, long long int*, Cell_head*)':
main.cpp:502:24: warning: deprecated conversion from string constant to
'char*' [-Wwrite-strings]
      obsElevOpt->answer = "1.75";
main.cpp:514:24: warning: deprecated conversion from string constant to
      tgtElevOpt->answer = "0.0";
main.cpp:557:26: warning: deprecated conversion from string constant to
      refrCoeffOpt->answer = "0.14286";
main.cpp:571:26: warning: deprecated conversion from string constant to
      memAmountOpt->answer = "500";
Status: Preprocessing c:\users\landa\appdata\local\temp\tmpfva_ht.h
Status: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
"-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
"-D__asm(x)=" "-DCTYPESGEN=1"
c:/users/landa/appdata/local/temp/tmpfva_ht.h
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG: In file included from
C:/msys64/mingw64/x86_64-w64-mingw32/include/_mingw.h:275:0,
-D__GLIBC_HAVE_LONG_LONG: from
C:/msys64/mingw64/x86_64-w64-mingw32/include/crtdefs.h:10,
C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:9,
C:\msys64\usr\src\grass_trunk\dist.x86_64-w64-mingw32\include\grass\gis.h:24,
c:/users/landa/appdata/local/temp/tmpfva_ht.h:1:
C:/msys64/mingw64/x86_64-w64-mingw32/include/vadefs.h:35:2: error: #error
VARARGS not implemented for this compiler
-D__GLIBC_HAVE_LONG_LONG: #error VARARGS not implemented for this
compiler
-D__GLIBC_HAVE_LONG_LONG: ^
Status: Parsing c:\users\landa\appdata\local\temp\tmpfva_ht.h
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:144: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:150: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:156: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:161: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:170: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:176: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:182: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:188: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:381: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:382: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:383: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:393: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:394: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:395: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:529: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:538: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:543: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:545: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:567: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:577: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:581: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:585: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:592: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:594: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:598: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:602: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:729: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:730: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:731: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:757: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:758: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:787: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:789: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:799: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:804: Syntax
error at 'argp'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:811: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:813: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:821: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:835: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:27:
Syntax error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:36:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:37:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:39:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:42:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:45:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:57:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:58:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:59:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:61:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:64:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:65:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:68:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:69:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:72:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:73:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:76:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:77:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:79:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:81:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:83:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:85:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:88:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:89:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:107:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:108:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:110:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:116:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:124:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:126:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:128:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:130:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:145:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:146:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:148:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:150:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:153:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:154:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:157:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:158:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:161:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:162:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:165:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:167:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:169:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:170:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:63:
Syntax error at '{'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:64:
Syntax error at ':'
Error:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/defs/gis.h:138:
Status: Preprocessing c:\users\landa\appdata\local\temp\tmplwqipi.h
c:/users/landa/appdata/local/temp/tmplwqipi.h
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/gis.h:24,
C:\msys64\usr\src\grass_trunk\dist.x86_64-w64-mingw32\include\grass\segment.h:4,
c:/users/landa/appdata/local/temp/tmplwqipi.h:1:
compiler
Status: Parsing c:\users\landa\appdata\local\temp\tmplwqipi.h
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at ';'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
error at 'va_list'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3368&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: All
Changes (by hellik):
* Attachment "package.zip" added.
zipped log file
Comment (by mmetz):
Replying to [ticket:3368 hellik]:
> looking into the
There will be many more compiler warnings with different compiler flags,
e.g. -Wall -Wextra -Wpedantic -Wshadow
As of trunk r71288, some of the warnings have been removed.
The errors in ctypes parsing C headers seem to be harmless, ctypes is
apparently working anyway. Getting rid of these error messages would be a
nice to have.
About the remaining compiler warnings:
There are various warnings like
warning: assignment discards 'const' qualifier from pointer target type
These are mostly harmless, it would be nice to get rid of them.
About iconv
MS Windows
parser_interface.c: In function 'print_escaped_for_xml':
parser_interface.c:67:20: warning: passing argument 2 of 'libiconv' from
   ret = iconv(conv, (char **)&src, &srclen, &dst, &dstlen);
In file included from parser_interface.c:32:0:
C:/OSGeo4W64/include/iconv.h:87:15: note: expected 'const char **' but
argument is of type 'char **'
  #define iconv libiconv
C:/OSGeo4W64/include/iconv.h:89:37: note: in expansion of macro 'iconv'
  extern LIBICONV_DLL_EXPORTED size_t iconv (iconv_t cd,
                                             const char **inbuf, size_t
*inbytesleft,
                                             char **outbuf, size_t
*outbytesleft);
Linux
        size_t iconv(iconv_t cd,
                     char **inbuf, size_t *inbytesleft,
                     char **outbuf, size_t *outbytesleft);
We could add `#ifdef __MINGW32__` clauses to avoid these warnings, but the
both the standard C and the GNU libiconv version expect `char **inbuf`,
not `const char **inbuf`, therefore I would leave it as it is.
put_row.c: In function 'write_null_bits_compressed':
put_row.c:509:29: warning: passing argument 1 of 'G_lz4_compress' discards
'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
      nwrite = G_lz4_compress(flags, size, compressed_buf, size);
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/gis.h:670:0,
                  from
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/raster.h:4,
                  from put_row.c:27:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/defs/gis.h:208:1:
note: expected 'unsigned char *' but argument is of type 'const unsigned
char *'
  G_lz4_compress(unsigned char *src, int src_sz, unsigned char *dst,
G_compress() and all G_*_compress() functions would need to be changed to
use const unsingned char *src, same for G_expand() and G_*_expand(). That
would make sense but is a (probably harmless) API change. Considering that
GRASS 7.2 is the first release to feature new compression methods, GRASS
7.2 could be regarded as a tech preview and minor changes in the API
related to the new feature might be ok.
`lib/driver/text3.c` same iconv issue as for parser_interface.c
`lib/cairodriver/text.c` same iconv issue as for parser_interface.c
[...]/include/grass/iostream/empq_adaptive.h: In constructor
[...]/include/grass/iostream/empq_adaptive.h:69:47: warning: delegating
constructors only available with -std=c++11 or -std=gnu++11
I guess the c++11 standard should not be a requirement. Any suggestions on
how to avoid that?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3368#comment:1&gt;
  Priority: normal | Milestone: 7.4.2
Comment (by martinl):
What is the state of this ticket?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3368#comment:4&gt;
Comment (by hellik):
Replying to [comment:4 martinl]:
warnings and errors still there
Ticket URL: <https://trac.osgeo.org/grass/ticket/3368#comment:5&gt;
  Priority: normal | Milestone: 7.4.5
Comment (by nila):
See !GitHub issue at https://github.com/OSGeo/grass/issues/1247 and
related PRs.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3368#comment:9&gt;
