#3369: Followup to area calculation fix in changeset 71169
Reporter: ndawson | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
While investigating the QGIS ticket https://issues.qgis.org/issues/16820 I
came across changeset 71169 as a fix for a similar issue in grass.
When porting this fix across to QGIS, I had to modify the thres constant
value to 0.7e-7, outside of the 1e-4 to 1e-7 range noted in the comment in
area_poly1.c. I found this to be the maximum possible value which allowed
an existing QGIS regression test to pass:
So this ticket is just a heads-up that the grass threshold value of 1e-6
may not be suitable, and this may need lowering to fix a real-world area
calculation issue.
About the first example (regression14675): what is SRSid 145L in EPSG or
proj4 terms?
About the second example (regression16820): GRASS reports an area of
43.3280133198665 sqm in the original CRS, and an area of 43.2035658006178
sqm reprojected to latlon. The QGIS test has a reference of 43.183369 sqm,
i.e. the projected GRASS result is a bit closer to the original than the
QGIS reference. The threshold as used in GRASS seems to work fine here.
calculation issue.
Waiting for SRS info on regression14675 to test in GRASS.
Resolution: | Keywords:
Comment (by ndawson):
proj4 terms?
Argh, missed that sorry. It's EPSG:2154.
Hmm - good point. To eliminate any discrepancies due to projection
handling/some other factor I tried using the original threshold of 1e-6 in
QGIS and got an area of
43.3280029296875.
I can't find a reliable threshold which satisfies both these requirements.
Ubuntu 16.04 with a threshold of 0.8e-7 does, but the same threshold on
Fedora 25 fails both tests.
Comment (by mmetz):
Replying to [comment:2 ndawson]:
or proj4 terms?
Thanks! Here are the results
* QGIS reference: 0.83301
* GRASS in EPSG:2154: 0.86121968362156
* GRASS in latlon: 3.3238796585328
I had to lower the threshold to 1e-8 in order to get
* GRASS in latlon: 0.86134805688084
> 43.3280029296875.
requirements. Ubuntu 16.04 with a threshold of 0.8e-7 does, but the same
threshold on Fedora 25 fails both tests.
This threshold method is not perfect. I found that the threshold must be
larger, the closer it gets to the equator, and smaller, the closer it gets
to the poles.
Comment (by mmetz):
Replying to [comment:3 mmetz]:
EPSG or proj4 terms?
After I applied the advice in my own comment, a threshold of 1e-6 works
fine
* GRASS in latlon: 0.861746563835888
If different latitudes are regarded as nearly identical (fabs(dy) <=
thresh), then the average of the two latitudes must be used, not one of
them.
Nice! I'm not sure if a constant threshold is a good idea, but at least
for the test cases and synthetic data from equator to pole the results
look reasonable.
Replying to [comment:6 martinl]:
> @mmetz Are you planning backport also to relbr70 or the ticket can be
simply closed? Thanks.
