#3380: v.what.vect query_column dropdown button doesn't show attribute columns of
query_map
Reporter: rorschach | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: 7.2.1
Keywords: v.what.vect | CPU: Unspecified
Platform: Linux |
A pleasant day to everyone.
Does anyone else encounter this problem? When I'm using v.what.vect, the
query_column dropdown button doesn't show the attribute columns of the
vector layer specified by query_map.
It's not too much of an issue since the user can always type the column
names manually but the dropdown button is supposed to be there to allow
the user to select the attribute columns of their query_map.
If anyone knows a fix or wants to fix this, I would highly appreciate it.
By the way, I'm using GRASS 7.2.1 on Xubuntu 16.04.
query_map
Resolution: | Keywords: v.what.vect
CPU: Unspecified | Platform: Linux
Comment (by mlennert):
Replying to [ticket:3380 rorschach]:
it.
This was fixed in trunk in r70518, but apparently never backported. I
don't know if there are objections to backporting... Martin ?
query_map
Comment (by rorschach):
Replying to [comment:1 mlennert]:
the query_column dropdown button doesn't show the attribute columns of the
column names manually but the dropdown button is supposed to be there to
allow the user to select the attribute columns of their query_map.
it.
Saw that fix when I searched for 'v.what.vect' tickets which is why I
found it weirder that the dropdown button wasn't working.
I copied the fix on my machine and everything seems to be working fine
now. A backport would also be appreciated.
