[GRASS-dev] [GRASS GIS] #3384: Ctypes detection doesn't work on OS X
Reporter: vince | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Compiling | Version: 7.2.1
Keywords: Python Ctype | CPU: OSX/Intel
Platform: MacOSX |
[As advised by Markus during the FOSS4G Europe]
When compiling GRASS 7.2.1 on MacOS 10.12, I get a slew of error messages
(but the compilation does not fail and the final grass binary seems to
work more or less fine).
GISRC=/opt/local/var/macports/build/_macports-
ports_gis_grass7/grass7/work/grass-7.2.1/dist.x86_64-apple-
darwin16.7.0/demolocation/.grassrc72 GISBASE=/opt/local/var/macports/build
/_macports-ports_gis_grass7/grass7/work/grass-7.2.1/dist.x86_64-apple-
darwin16.7.0 PATH="/opt/local/var/macports/build/_macports-
darwin16.7.0/bin:/opt/local/var/macports/build/_macports-
darwin16.7.0/scripts:$PATH" PYTHONPATH="/opt/local/var/macports/build
darwin16.7.0/etc/python:/opt/local/var/macports/build/_macports-
darwin16.7.0/gui/wxpython:$PYTHONPATH"
DYLD_LIBRARY_PATH="/opt/local/var/macports/build/_macports-
darwin16.7.0/scripts:/opt/local/var/macports/build/_macports-
darwin16.7.0/lib:/opt/local/var/macports/build/_macports-
darwin16.7.0/lib:" LC_ALL=C ./ctypesgen.py --cpp "/usr/bin/clang -E
-I/opt/local/include -I/opt/local/var/macports/build/_macports-
darwin16.7.0/include -I/opt/local/var/macports/build/_macports-
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_imagery.7.2.1
darwin16.7.0/include/grass/imagery.h /opt/local/var/macports/build
darwin16.7.0/include/grass/defs/imagery.h -o OBJ.x86_64-apple-
darwin16.7.0/imagery.py
Status: Preprocessing /opt/local/var/macports/build/_macports-
ports_gis_grass7/grass7/work/.tmp/tmpXOMmQY.h
Status: /usr/bin/clang -E -I/opt/local/include
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG -U __BLOCKS__ -U __GNUC__
-dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t"
"-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1"
"-D__uint16_t=uint16_t" "-D__uint32_t=uint32_t" "-D__uint64_t=uint64_t"
Error: /usr/bin/clang -E -I/opt/local/include
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG: In file included from
ports_gis_grass7/grass7/work/.tmp/tmpXOMmQY.h:1:
darwin16.7.0/include/grass/gis.h:24:
/usr/include/stdio.h:64:
/usr/include/sys/cdefs.h:81:2: warning: "Unsupported compiler detected"
[-W#warnings]
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG: #warning "Unsupported
compiler detected"
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG: ^
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG: 1 warning generated.
Status: Parsing /opt/local/var/macports/build/_macports-
Error: /usr/include/sys/stdio.h:39: Syntax error at '__attribute__'
Error: /usr/include/sys/stdio.h:39: Syntax error at '='
Error: /usr/include/sys/stdio.h:46: Syntax error at '__attribute__'
Error: /usr/include/sys/stdio.h:46: Syntax error at '='
Error: /usr/include/sys/stdio.h:47: Syntax error at '__attribute__'
Error: /usr/include/sys/stdio.h:47: Syntax error at '='
Error: /usr/include/stdio.h:133: Syntax error at '_close'
Error: /usr/include/stdio.h:134: Syntax error at '_read'
Error: /usr/include/stdio.h:135: Syntax error at '_seek'
Error: /usr/include/stdio.h:136: Syntax error at '_write'
Error: /usr/include/stdio.h:136: Syntax error at ','
Error: /usr/include/stdio.h:153: Syntax error at '}'
Error: /usr/include/stdio.h:231: Syntax error at '*'
Error: /usr/include/stdio.h:232: Syntax error at '*'
Error: /usr/include/stdio.h:233: Syntax error at '*'
Error: /usr/include/stdio.h:234: Syntax error at '*'
Error: /usr/include/stdio.h:235: Syntax error at '*'
Error: /usr/include/stdio.h:236: Syntax error at '*'
Error: /usr/include/stdio.h:237: Syntax error at '*'
Error: /usr/include/stdio.h:238: Syntax error at 'FILE'
Error: /usr/include/stdio.h:242: Syntax error at '__filename'
Error: /usr/include/stdio.h:242: Syntax error at '__mode'
Error: /usr/include/stdio.h:244: Syntax error at '*'
Error: /usr/include/stdio.h:244: Syntax error at '...'
Error: /usr/include/stdio.h:244: Syntax error at 'i2'
Error: /usr/include/stdio.h:245: Syntax error at 'FILE'
Error: /usr/include/stdio.h:246: Syntax error at 'FILE'
Error: /usr/include/stdio.h:247: Syntax error at '__ptr'
Error: /usr/include/stdio.h:247: Syntax error at 'size_t'
Error: /usr/include/stdio.h:249: Syntax error at 'FILE'
Error: /usr/include/stdio.h:250: Syntax error at '*'
Error: /usr/include/stdio.h:250: Syntax error at '...'
Error: /usr/include/stdio.h:250: Syntax error at 'i2'
Error: /usr/include/stdio.h:251: Syntax error at '*'
Error: /usr/include/stdio.h:252: Syntax error at '*'
Error: /usr/include/stdio.h:252: Syntax error at ')'
Error: /usr/include/stdio.h:253: Syntax error at '*'
Error: /usr/include/stdio.h:254: Syntax error at '__ptr'
Error: /usr/include/stdio.h:254: Syntax error at 'size_t'
Error: /usr/include/stdio.h:255: Syntax error at '*'
Error: /usr/include/stdio.h:259: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:259: Syntax error at 'i1'
Error: /usr/include/stdio.h:260: Syntax error at 'FILE'
Error: /usr/include/stdio.h:265: Syntax error at '*'
Error: /usr/include/stdio.h:266: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:266: Syntax error at 'i1'
Error: /usr/include/stdio.h:267: Syntax error at '*'
Error: /usr/include/stdio.h:267: Syntax error at ')'
Error: /usr/include/stdio.h:268: Syntax error at '*'
Error: /usr/include/stdio.h:268: Syntax error at 'int'
Error: /usr/include/stdio.h:269: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:269: Syntax error at 'i2'
Error: /usr/include/stdio.h:269: Syntax error at '='
Error: /usr/include/stdio.h:270: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:270: Syntax error at 'i2'
Error: /usr/include/stdio.h:271: Syntax error at ';'
Error: /usr/include/stdio.h:273: Syntax error at '='
Error: /usr/include/stdio.h:278: Syntax error at 'FILE'
Error: /usr/include/stdio.h:279: Syntax error at '*'
Error: /usr/include/stdio.h:279: Syntax error at 'va_list'
Error: /usr/include/stdio.h:279: Syntax error at 'i2'
Error: /usr/include/stdio.h:280: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:280: Syntax error at 'i1'
Error: /usr/include/stdio.h:281: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:281: Syntax error at 'i2'
Error: /usr/include/stdio.h:281: Syntax error at '='
Error: /usr/include/stdio.h:303: Syntax error at '*'
Error: /usr/include/stdio.h:303: Syntax error at ';'
Error: /usr/include/stdio.h:305: Syntax error at '*'
Error: /usr/include/stdio.h:321: Syntax error at '*'
Error: /usr/include/stdio.h:321: Syntax error at '='
Error: /usr/include/stdio.h:325: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:325: Syntax error at '='
Error: /usr/include/stdio.h:342: Syntax error at '*'
Error: /usr/include/stdio.h:343: Syntax error at '*'
Error: /usr/include/stdio.h:343: Syntax error at ','
Error: /usr/include/stdio.h:343: Syntax error at 'i2'
Error: /usr/include/stdio.h:344: Syntax error at 'FILE'
Error: /usr/include/stdio.h:379: Syntax error at '*'
Error: /usr/include/stdio.h:380: Syntax error at '*'
Error: /usr/include/stdio.h:381: Syntax error at '*'
Error: /usr/include/stdio.h:382: Syntax error at '*'
Error: /usr/include/stdio.h:384: Syntax error at 'FILE'
Error: /usr/include/stdio.h:389: Syntax error at '*'
Error: /usr/include/stdio.h:390: Syntax error at 'FILE'
Error: /usr/include/stdio.h:393: Syntax error at '='
Error: /usr/include/stdio.h:420: Syntax error at '*'
Error: /usr/include/stdio.h:420: Syntax error at 'int'
Error: /usr/include/stdio.h:421: Syntax error at '*'
Error: /usr/include/stdio.h:427: Syntax error at '__str'
Error: /usr/include/stdio.h:427: Syntax error at 'const'
Error: /usr/include/stdio.h:427: Syntax error at '__format'
Error: /usr/include/stdio.h:427: Syntax error at 'i3'
Error: /usr/include/stdio.h:428: Syntax error at '*'
Error: /usr/include/stdio.h:428: Syntax error at '__format'
Error: /usr/include/stdio.h:428: Syntax error at 'i2'
Error: /usr/include/stdio.h:429: Syntax error at '__format'
Error: /usr/include/stdio.h:429: Syntax error at 'i1'
Error: /usr/include/stdio.h:430: Syntax error at '__str'
Error: /usr/include/stdio.h:430: Syntax error at 'const'
Error: /usr/include/stdio.h:430: Syntax error at '__format'
Error: /usr/include/stdio.h:430: Syntax error at 'i3'
Error: /usr/include/stdio.h:431: Syntax error at '__str'
Error: /usr/include/stdio.h:431: Syntax error at '__format'
Error: /usr/include/stdio.h:431: Syntax error at 'i2'
Error: /usr/include/stdio.h:445: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:445: Syntax error at 'i2'
Error: /usr/include/stdio.h:445: Syntax error at '='
Error: /usr/include/stdio.h:446: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:446: Syntax error at 'i2'
Error: /usr/include/stdio.h:446: Syntax error at '='
Error: /usr/include/stdio.h:447: Syntax error at '__linep'
Error: /usr/include/stdio.h:447: Syntax error at '__linecapp'
Error: /usr/include/stdio.h:447: Syntax error at '*'
Error: /usr/include/stdio.h:447: Syntax error at '='
Error: /usr/include/stdio.h:448: Syntax error at '__linep'
Error: /usr/include/stdio.h:448: Syntax error at '__linecapp'
Error: /usr/include/stdio.h:448: Syntax error at '='
Error: /usr/include/stdio.h:461: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:461: Syntax error at 'i2'
Error: /usr/include/stdio.h:463: Syntax error at '*'
Error: /usr/include/stdio.h:465: Syntax error at '*'
Error: /usr/include/stdio.h:466: Syntax error at '*'
Error: /usr/include/stdio.h:467: Syntax error at '*'
Error: /usr/include/stdio.h:468: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:468: Syntax error at 'i2'
Error: /usr/include/stdio.h:469: Syntax error at ';'
Error: /usr/include/stdio.h:479: Syntax error at ';'
Error: /opt/local/var/macports/build/_macports-
darwin16.7.0/include/grass/gis.h:576: Syntax error at 'FILE'
darwin16.7.0/include/grass/gis.h:578: Syntax error at '}'
darwin16.7.0/include/grass/defs/gis.h:161: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:363: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/gis.h:364: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/gis.h:408: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:408: Syntax error at ')'
darwin16.7.0/include/grass/defs/gis.h:409: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:464: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/gis.h:465: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/gis.h:526: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:526: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:527: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:528: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:529: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:535: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:535: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:537: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:538: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:539: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:545: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:545: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:547: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:547: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:564: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:564: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:565: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:595: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:595: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:596: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:649: Syntax error at '*'
ports_gis_grass7/grass7/work/gStatus: Preprocessing
ports_gis_grass7/grass7/work/.tmp/tmpg6r1gq.h
ports_gis_grass7/grass7/work/.tmp/tmpg6r1gq.h:1:
darwin16.7.0/include/grass/raster.h:4:
[-W#warnings]
compiler detected"
ports_gis_grass7/grass7/work/grass-7.2.1/dist.x86_64-appStatus:
ports_gis_grass7/grass7/work/.tmp/tmpC6LnCT.h
ports_gis_grass7/grass7/work/.tmp/tmpC6LnCT.h:1:
darwin16.7.0/include/grass/imagery.h:4:
[-W#warnings]
compiler detected"
ports_gis_grass7/grass7/work/grass-7.2.1/dist.x86_64-aprass-7.2.1/dist.x86_64
-apple-darwin16.7.0/include/grass/defs/gis.h:649: Syntax error at ','
darwin16.7.0/include/grass/defs/gis.h:670: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:671: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:714: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:714: Syntax error at ';'
darwin16.7.0/include/grass/defs/gis.h:721: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:721: Syntax error at ')'
darwin16.7.0/include/grass/defs/gis.h:819: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:819: Syntax error at ','
darwin16.7.0/include/grass/defs/gis.h:820: Syntax error at '*'
darwin16.7.0/include/grass/defs/gis.h:820: Syntax error at ','
Status: Processing description list.
Warning: Member "from" of Struct "DateTime" has been renamed to "_from"
because it has the same name as a Python keyword.
Warning: Member "def" of Struct "Option" has been renamed to "_def"
Warning: Could not parse macro "#define serialize_int32_le(buf,x) do { (
buf ) [ i0 ] = ( ( x ) >> i0 ) & i255 ; ( buf ) [ i1 ] = ( ( x ) >> i8 ) &
i255 ; ( buf ) [ i2 ] = ( ( x ) >> i16 ) & i255 ; ( buf ) [ i3 ] = ( ( x )
>> i24 ) & i255 ; } while ( i0 )"
Warning: Could not parse macro "#define serialize_int32_be(buf,x) do { (
buf ) [ i0 ] = ( ( x ) >> i24 ) & i255 ; ( buf ) [ i1 ] = ( ( x ) >> i16 )
& i255 ; ( buf ) [ i2 ] = ( ( x ) >> i8 ) & i255 ; ( buf ) [ i3 ] = ( ( x
) >> i0 ) & i255 ; } while ( i0 )"
Status: Writing to OBJ.x86_64-apple-darwin16.7.0/gis.py.
Status: Wrapping complete.
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_vector.7.2.1
-I/opt/local/include/postgresql96 -I/opt/local/include
-I/opt/local/include /opt/local/var/macports/build/_macports-
darwin16.7.0/include/grass/vector.h /opt/local/var/macports/build
darwin16.7.0/include/grass/defs/vector.h /opt/local/var/macports/build
darwin16.7.0/include/grass/vect/dig_structs.h
darwin16.7.0/include/grass/vect/dig_defines.h
darwin16.7.0/include/grass/vect/dig_externs.h -o OBJ.x86_64-apple-
darwin16.7.0/vector.py
le-darwin16.7.0/include/grass/defs/gis.h:595: Syntax error at ';'
darwin16.7.0/include/grass/defs/raster.h:179: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/raster.h:257: Syntax error at '*'
darwin16.7.0/include/grass/defs/raster.h:257: Syntax error at ')'
darwin16.7.0/include/grass/defs/raster.h:361: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/raster.h:363: Syntax error at 'FILE'
Status: Writing to OBJ.x86_64-apple-darwin16.7.0/raster.py.
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_rtree.7.2.1
darwin16.7.0/include/grass/rtree.h -o OBJ.x86_64-apple-
darwin16.7.0/rtree.py
ple-darwin16.7.0/include/grass/defs/gis.h:595: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:17: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/imagery.h:27: Syntax error at '*'
darwin16.7.0/include/grass/defs/imagery.h:27: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:28: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:29: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:30: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:31: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:32: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:92: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/imagery.h:93: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/imagery.h:97: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/imagery.h:98: Syntax error at 'FILE'
darwin16.7.0/include/grass/defs/imagery.h:110: Syntax error at '*'
darwin16.7.0/include/grass/defs/imagery.h:110: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:111: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:112: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:113: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:141: Syntax error at '*'
darwin16.7.0/include/grass/defs/imagery.h:141: Syntax error at ')'
darwin16.7.0/include/grass/defs/imagery.h:142: Syntax error at '*'
darwin16.7.0/include/grass/defs/imagery.h:142: Syntax error at ')'
darwin16.7.0/include/grass/defs/imagery.h:143: Syntax error at '*'
darwin16.7.0/include/grass/defs/imagery.h:143: Syntax error at ')'
darwin16.7.0/include/grass/defs/imagery.h:146: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:147: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:156: Syntax error at '*'
darwin16.7.0/include/grass/defs/imagery.h:156: Syntax error at ')'
darwin16.7.0/include/grass/defs/imagery.h:161: Syntax error at '*'
darwin16.7.0/include/grass/defs/imagery.h:161: Syntax error at ')'
darwin16.7.0/include/grass/defs/imagery.h:164: Syntax error at ';'
darwin16.7.0/include/grass/defs/imagery.h:165: Syntax error at ';'
Status: Writing to OBJ.x86_64-apple-darwin16.7.0/imagery.py.
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_display.7.2.1
darwin16.7.0/include/grass/display.h /opt/local/var/macports/build
darwin16.7.0/include/grass/defs/display.h -o OBJ.x86_64-apple-
darwin16.7.0/display.py
ports_gis_grass7/grass7/work/.tmp/tmp3HfhxA.h
ports_gis_grass7/grass7/work/.tmp/tmp3HfhxA.h:1:
darwin16.7.0/include/grass/rtree.h:21:
/usr/include/stdlib.h:63:
/usr/include/_types.h:27:
/usr/include/sys/_types.h:32:
[-W#warnings]
compiler detected"
Error: /usr/include/sys/resource.h:387: Syntax error at '__attribute__'
Error: /usr/include/sys/resource.h:387: Syntax error at '='
Error: /usr/include/sys/resource.h:393: Syntax error at '__attribute__'
Error: /usr/include/sys/resource.h:393: Syntax error at '='
Error: /usr/include/stdlib.h:128: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:128: Syntax error at ';'
Error: /usr/include/stdlib.h:129: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:139: Syntax error at '__compar'
Error: /usr/include/stdlib.h:139: Syntax error at ')'
Error: /usr/include/stdlib.h:140: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:140: Syntax error at ';'
Error: /usr/include/stdlib.h:141: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:142: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:142: Syntax error at ';'
Error: /usr/include/stdlib.h:145: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:146: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:152: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:152: Syntax error at ';'
Error: /usr/include/stdlib.h:156: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:156: Syntax error at '='
Error: /usr/include/stdlib.h:158: Syntax error at '__compar'
Error: /usr/include/stdlib.h:158: Syntax error at ')'
Error: /usr/include/stdlib.h:159: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:159: Syntax error at '='
Error: /usr/include/stdlib.h:160: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:160: Syntax error at ';'
Error: /usr/include/stdlib.h:161: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:161: Syntax error at '='
Error: /usr/include/stdlib.h:184: Syntax error at '('
Error: /usr/include/stdlib.h:184: Syntax error at '='
Error: /usr/include/stdlib.h:185: Syntax error at '='
Error: /usr/include/stdlib.h:186: Syntax error at ')'
Error: /usr/include/stdlib.h:195: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:195: Syntax error at ';'
Error: /usr/include/stdlib.h:209: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:209: Syntax error at '='
Error: /usr/include/stdlib.h:212: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:212: Syntax error at '='
Error: /usr/include/stdlib.h:215: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:215: Syntax error at '='
Error: /usr/include/stdlib.h:216: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:216: Syntax error at '='
Error: /usr/include/stdlib.h:220: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:220: Syntax error at '='
Error: /usr/include/stdlib.h:221: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:221: Syntax error at '='
Error: /usr/include/stdlib.h:259: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:259: Syntax error at '='
Error: /usr/include/stdlib.h:260: Syntax error at '='
Error: /usr/include/stdlib.h:261: Syntax error at '='
Error: /usr/include/stdlib.h:262: Syntax error at '='
Error: /usr/include/stdlib.h:263: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:263: Syntax error at '='
Error: /usr/include/stdlib.h:266: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:266: Syntax error at '='
Error: /usr/include/stdlib.h:285: Syntax error at '__attribute__'
Error: /usr/include/stdlib.h:285: Syntax error at '='
Error: /usr/include/stdlib.h:285: Syntax error at ')'
Error: /usr/include/stdlib.h:294: Syntax error at '__compar'
Error: /usr/include/stdlib.h:294: Syntax error at ')'
Error: /usr/include/stdlib.h:300: Syntax error at '__compar'
Error: /usr/include/stdlib.h:300: Syntax error at ')'
Error: /usr/include/stdlib.h:306: Syntax error at '__compar'
Error: /usr/include/stdlib.h:306: Syntax error at ')'
Error: /usr/include/stdlib.h:306: Syntax error at '='
Error: /usr/include/stdlib.h:312: Syntax error at '__compar'
Error: /usr/include/stdlib.h:312: Syntax error at ','
Error: /usr/include/stdlib.h:312: Syntax error at ')'
Error: /usr/include/stdlib.h:312: Syntax error at '='
Error: /usr/include/stdlib.h:318: Syntax error at '__compar'
Error: /usr/include/stdlib.h:318: Syntax error at ','
Error: /usr/include/stdlib.h:318: Syntax error at ')'
Error: /usr/include/string.h:131: Syntax error at '__attribute__'
Error: /usr/include/string.h:131: Syntax error at '='
Error: /usr/include/string.h:132: Syntax error at '__attribute__'
Error: /usr/include/string.h:132: Syntax error at '='
Error: /usr/include/string.h:133: Syntax error at '__attribute__'
Error: /usr/include/string.h:133: Syntax error at '='
Error: /usr/include/string.h:145: Syntax error at '__attribute__'
Error: /usr/include/string.h:145: Syntax error at '='
Error: /usr/include/string.h:155: Syntax error at '__attribute__'
Error: /usr/include/string.h:155: Syntax error at '='
Error: /usr/include/string.h:156: Syntax error at '__attribute__'
Error: /usr/include/string.h:156: Syntax error at '='
Error: /usr/include/string.h:157: Syntax error at '__attribute__'
Error: /usr/include/string.h:157: Syntax error at '='
Error: /usr/include/string.h:158: Syntax error at '__attribute__'
Error: /usr/include/string.h:158: Syntax error at '='
Error: /usr/include/string.h:171: Syntax error at '('
Error: /usr/include/string.h:171: Syntax error at '='
Error: /usr/include/string.h:172: Syntax error at '='
Error: /usr/include/strings.h:85: Syntax error at '__attribute__'
Error: /usr/include/strings.h:85: Syntax error at '='
Error: /usr/include/strings.h:86: Syntax error at '__attribute__'
Error: /usr/include/strings.h:86: Syntax error at '='
Error: /usr/include/strings.h:87: Syntax error at '__attribute__'
Error: /usr/include/strings.h:87: Syntax error at '='
Error: /usr/include/strings.h:88: Syntax error at '__attribute__'
Error: /usr/include/strings.h:88: Syntax error at '='
Error: /usr/include/strings.h:89: Syntax error at '__attribute__'
Error: /usr/include/strings.h:89: Syntax error at '='
Status: Writing to OBJ.x86_64-apple-darwin16.7.0/rtree.py.
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_stats.7.2.1
darwin16.7.0/include/grass/stats.h /opt/local/var/macports/build
darwin16.7.0/include/grass/defs/stats.h -o OBJ.x86_64-apple-
darwin16.7.0/stats.py
ports_gis_grass7/grass7/work/.tmp/tmpKGMpLV.h
ports_gis_grass7/grass7/work/.tmp/tmpKGMpLV.h:1:
darwin16.7.0/include/grass/display.h:4:
[-W#warnings]
compiler detected"
Status: Writing to OBJ.x86_64-apple-darwin16.7.0/display.py.
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_dbmiclient.7.2.1
-lgrass_dbmibase.7.2.1 /opt/local/var/macports/build/_macports-
darwin16.7.0/include/grass/dbmi.h /opt/local/var/macports/build/_macports-
darwin16.7.0/include/grass/defs/dbmi.h -o OBJ.x86_64-apple-
darwin16.7.0/dbmi.py
ports_gis_grass7/grass7/work/.tmp/tmp7bH0pa.h
ports_gis_grass7/grass7/work/.tmp/tmp7bH0pa.h:1:
darwin16.7.0/include/grass/stats.h:4:
[-W#warnings]
compiler detected"
Status: Writing to OBJ.x86_64-apple-darwin16.7.0/stats.py.
darwin16.7.0/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_g3d.7.2.1
darwin16.7.0/include/grass/raster3d.h /opt/local/var/macports/build
darwin16.7.0/include/grass/defs/raster3d.h -o OBJ.x86_64-apple-
darwin16.7.0/raster3d.py
ports_gis_grass7/grass7/work/.tmp/tmpsv6YZi.h
-dD -I/opt/local/include -I/opt/local/include "-Dinline=" "-D__inline__="
"-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
"-D__asm(x)=" "-DCTYPESGEN=1" "-D__uint16_t=uint16_t"
ports_gis_grass7/grass7/work/.tmp/tmpsv6YZi.h:1:
darwin16.7.0/include/grass/gprojects.h:21:
/opt/local/include/proj_api.h:33:
/usr/include/math.h:30:
[-W#warnings]
compiler detected"
Etc.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3384&gt;
Resolution: | Keywords: Python Ctype
       CPU: OSX/Intel | Platform: MacOSX
Comment (by hellik):
Replying to [ticket:3384 vince]:
It looks similar to #3368
Ticket URL: <https://trac.osgeo.org/grass/ticket/3384#comment:1&gt;
Comment (by vince):
Replying to [comment:1 hellik]:
Yeah, a subset of it, apparently. Any clue as to what's causing this yet?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3384#comment:2&gt;
  Priority: normal | Milestone: 7.8.0
Changes (by neteler):
* milestone: 7.2.4 => 7.8.0
Comment:
Does the problem persist with the current trunk version?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3384#comment:4&gt;
Comment (by vince):
I’ll have a go later today and let you know
Ticket URL: <https://trac.osgeo.org/grass/ticket/3384#comment:5&gt;
  Priority: normal | Milestone: 7.8.3
Comment (by nila):
I can confirm this is still an issue on master (7.9.dev) as well as 7.8.2.
But as previously mentioned it doesn't seem to cause any compiling or
other problems.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3384#comment:10&gt;
Comment (by nila):
The [https://github.com/OSGeo/grass/pull/507 PR#507] attempts to address
this issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3384#comment:11&gt;
