#3387: r.to.vect fails on a properly thinned tif via r.thin/r.null
Reporter: hbgdal | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.2.0
Keywords: | CPU: Unspecified
Platform: Linux |
Hi, This happens only on a small number of tif files. Most of the tif
files are processed successfully. Commands to reproduce problem with 7.2.0
are pasted below. I would appreciate any workaround/patch(for 7.2.0 or any
other version) for this fix.
Problem:
For some tifs, the r.to.vect fails complaining that the image needs to be
thinned, and then hangs with a message about busy SQLite DB.
Expected behavior:
Either r.to.vect should extract lines from thinned image, or r.thin should
thin the image further.
Env:
Ubuntu 14.04. 7.2.0 compiled
Commands to run:
#This is "binary" image with two colors black and white
r.in.gdal input=/tmp/grass_problem.tif output=grass_problem
location=grass_problem
#Replace "white" color with null for r.thin.
r.null --verbose map=grass_problem@PERMANENT setnull=255
#r.thin succeeds in less than 10 iterations.(See output below)
r.thin --verbose input=grass_problem@PERMANENT output=grass_thin
#r.to.vect complains.
r.to.vect --verbose input=grass_thin@PERMANENT output=vec_lines type=line
===== r.thin output showing success ====
Raster map <grass_problem@PERMANENT> - 4028 rows X 3288 columns
Bounding box: l = 3, r = 3284, t = 7, b = 4028
Pass number 1
Deleted 240415 pixels
Pass number 2
Deleted 5154 pixels
Pass number 3
Deleted 115 pixels
Pass number 4
Deleted 5 pixels
Pass number 5
Deleted 0 pixels
Thinning completed successfully.
Output map 4028 rows X 3288 columns
Window 4028 rows X 3288 columns
(Thu Aug 3 11:17:10 2017) Command finished (2 sec)
=== r.to.vect output showing failure ===
Using native format
Extracting lines...
Crowded cell at (362.125000, 12883.540000): row 424, col 1721, count 7
ERROR: Raster map is not thinned properly.
Please run r.thin.
WARNING: Busy SQLITE db, already waiting for 10 seconds.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3387>
