#339: d.mon doesn't work (WinGrass commandline)
Reporter: schulzea | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0 RCs
Keywords: | Platform: MSWindows XP
Cpu: Unspecified |
I have installed WinGrass 6.3.0-4 on WindowsXP SP3.
I used the windows installer.
When I start WinGrass via command line, I can't open the monitor (d.mon
start=x0).
The following error messages appear:
ERROR: no such monitor 'x0'
ERROR: No such monitor as 'x0'
Problem selecting x0. Will try once more
okay, not so nice.
Are there plans to include x monitors in WinGrass or is this not possible?
It is pretty annoying to run the script under WinGrass commandline and
then have to change to WinGrass GUI to see the results.
Or is there a possibility to use the shell in the GUI-version
> okay, not so nice.
possible?
We never managed to figure out how to create a socket which works with
read() and write(), and changing the code to use Windows-specific
equivalents was too much work. In 7.0, monitors have been removed
entirely.
You should be able to start a command-line session then start the GUI with
g.gui. Or look for an image viewer which has an option to automatically
re-load the file if it is modified, and use it to view the map.png file
created by d.* commands.
Replying to [comment:1 hamish]:
> X monitors do not exist in native MS windows. You must use the GUI or
install the cygwin version.
> Perhaps an #ifdef could be added to d.mon so the module reports
something to this effect rather than leave the user confused.
It might be better to just omit d.mon on Windows. The program itself
compiles fine, but as none of the drivers exist, there isn't much point in
d.mon existing.
Replying to [comment:5 glynn]:
d.mon existing.
d.mon is used in a number of scripts (+user; +addon; but most importantly
in my eyes d.out.file), and it would be much kinder to users to have a
G_fatal_error("This module does not work in WinGRASS") or such [+exit(1)],
rather than some cryptic msys message that some command was not found half
way through the script that calls it. Followed by the inevitable FAQ post
to the mailing list asking where to find it.
(I am thinking of WinGRASS 6.4.0 here)
Replying to [comment:8 pkelly]:
> Are you getting at that scripts using "d.mon start=x0" should run
> d.mon -l first to check that x0 is available? Sounds very
> reasonable.
