[GRASS-dev] [GRASS GIS] #3393: t.unregister: encoding error
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Keywords: t.unregister encoding | CPU: Unspecified
Platform: Unspecified |
As a corollary to #3392:
g.list type=raster pattern="*tempmean" output=fichier_cartes_tempmean
t.create output=pluies_nc semantictype=sum title=precipitation_mois
description="Précipitation totale mensuelle NC"
t.register -i input=pluies_nc@climate_2000_2012
file=fichier_cartes_tempmean start=2000-01-01 increment="1 months"
Collecte des informations sur la carte ...
t.unregister file=fichier_cartes_tempmean
Unregister maps
  100%
Unregister maps from the temporal database
   File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/scripts/t.unregister", line 183, in <module>
     tgis.profile_function(main)
gnu/etc/python/grass/temporal/core.py", line 84, in profile_function
     func()
gnu/scripts/t.unregister", line 169, in main
     sp.update_from_registered_maps(dbif)
gnu/etc/python/grass/temporal/abstract_space_time_dataset.py", line 2292,
in update_from_registered_maps
     " all registered maps of <%s>") % (self.get_id()))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 7:
ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3393&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords: t.unregister encoding
Changes (by mlennert):
* status: new => closed
* resolution: => duplicate
Comment:
As this seems to be a general problem, all discussion should go on in
#3392.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3393#comment:1&gt;
