[GRASS-dev] [GRASS GIS] #3397: db.select - reading multiline SQL statements from file fails
Reporter: maitl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Database | Version: 7.2.1
Keywords: | CPU: Unspecified
Platform: All |
It is convenient to store longer SQL statements into file.
If each statement is not exactly one line in input file, then db.select
ends with error.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3397&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: All
Changes (by maitl):
* Attachment "query_examples_single_line_and_multi-line.zip" added.
  Priority: normal | Milestone: 7.2.2
Resolution: | Keywords: db.select, db.execute
Changes (by martinl):
* keywords: => db.select, db.execute
* milestone: => 7.2.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3397#comment:1&gt;
  Priority: normal | Milestone: 7.4.0
Changes (by mlennert):
* milestone: 7.2.2 => 7.4.0
Comment:
Replying to [ticket:3397 maitl]:
ends with error.
This is due to the fact that db.select reads the input file line by line,
and then uses all text before a semi-colon as the SQL statement.
This means that with a file test.sql that contains
SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38;
SELECT count(*) FROM boundary_county;
you get
count(*)
333
count(*)
926
while if the file contains
SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38; SELECT count(*)
you only get
count(*)
333
The same happens when you do this:
echo "SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38; SELECT
count(*) FROM boundary_county;" | db.select input=-
and I cannot integrate a newline ('\n') character:
echo "SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38\n; SELECT
DBMI-SQLite erreur de pilote :
Error in sqlite3_prepare():
SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38\n; SELECT count(*)
unrecognized token: "\"
A rewrite of this to more flexibly parse the SQL, be it with one statement
over several lines, or several statements on one line would be nice, but I
would consider this too invasive to go into 7.2.2.
So, I propose that for 7.2.2 we just amend the manual. I've taken the
liberty to add one sentence about that in trunk and release72 (r71389 and
r71390).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3397#comment:2&gt;
Comment (by mlennert):
Replying to [comment:2 mlennert]:
Sorry, the '\n' was not well placed. It should have been
echo "SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38;\n SELECT
database=GRASS/GRASSDATA/NC_spm_temporal_workshop/PERMANENT/sqlite/sqlite.db
count(*)
333
So, no error, but the query on the second line does not get executed...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3397#comment:3&gt;
Comment (by mmetz):
Replying to [comment:3 mlennert]:
> count(*)
> 333
You need to use echo -e (enable interpretation of backslash escapes).
About the main issue, we could introduce a new flag, e.g. -m, to allow
multiline statements: only a semicolon, not a newline would mark the end
of a statement.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3397#comment:4&gt;
