[GRASS-dev] [GRASS GIS] #340: d.labels doesn't place labels exactly on coordinate point in label file.
Reporter: wolf | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: Unspecified |
The attached patch fixes the issue by introducing a new keyword none for
label placement, which will keep the label exactly on the coordinate
point, without affecting the other placement algorithms of d.labels. This
is needed for v.label.sa to work correctly, since it calculates the exact
position where a label can be placed with minimum overlap. The secnd patch
also adds support for the none placement keyword to ps.map
Ticket URL: <http://trac.osgeo.org/grass/ticket/340&gt;
  Reporter: wolf | Owner: hamish
      Type: enhancement | Status: assigned
Resolution: | Keywords:
  Platform: All | Cpu: Unspecified
Changes (by hamish):
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/340#comment:2&gt;
Comment (by hamish):
do I have this right?
d.labels: patch skips adjustments for dealing with multi-line labels
(desired?), and puts bottom left corner of text box at the exact
coordinate.
like:
   _____________
  .|_text here_|
ps.map: just like LOWER,LEFT placement but without any X,Y_just_offset
which keeps the label off of the symbol.
I would prefer, in this order:
  - use ref: center,center as the basis for offsets
  - ref: bottom_0,left_0 instead of none,none to indicate where + no
padding.
If it can be done with "ref: center,center" I'd be a lot happier.
some other points:
  - I would not move the above rendering offsets into v.label.
  - From the user's perspective I'd think they'd expect SA placement to be
an optional flag of v.label. Codewise that may be harder, but I am just
speaking about what a user might expect and long term goals.
  - I do not have plans to replace v.label with v.label.sa. For one thing
v.label has had some fixes after v.label.sa forked which AFAIK have not
been ported (mostly to do with correctly handling rotation). I suspect
there are a few other small things.
  - v.label does not sort smallest label on top, nor (by default) IMO
should it. Fine for SA, but isn't the whole point of SA that they not
overlap in the first place, so not an issue?. See related filled-area
"v.bubbleplot" for/against discussions to sort points to put smallest
circles on top.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/340#comment:3&gt;
      Type: enhancement | Status: closed
Resolution: worksforme | Keywords:
Changes (by wolf):
  * status: assigned => closed
  * resolution: => worksforme
Comment:
Replying to [comment:3 hamish]:
> bottom left corner of text box at the exact coordinate.
> off of the symbol.
Yes, that is correct. It keeps track of all the lower left points of
labels. However multi-line labels might not work. I haven't tested.
padding.
Okay. Thanks for that. I'll change the v.label.sa to calculate the center
point, and use ref: center center
> some other points:
That is quite ok with the "inexact labels", I suppose that the label
placement code could be moved to d.labels instead, and would work with on
screen pixels... Perhaps it will be done so in the future. I made it this
way because now I have an easy way to access vector layer info such as
points, lines etc.
be an optional flag of v.label. Codewise that may be harder, but I am just
I agree.
v.label.sa is '''NOT''' a fork or v.label, it doesn't do the "ordinary"
label placement as v.label does. It only does "optimized" label placement.
It does share a tiny fragment of code with v.label, namely the generation
of the labels file entries, but even that is not a direct copy. It does
have compatible options for ease of use.
circles on top.
Nor does v.label.sa. It now has an optional feature to hide all
overlapping labels except for the one with the greatest weight.
--Wolf
Ticket URL: <https://trac.osgeo.org/grass/ticket/340#comment:4&gt;
