[GRASS-dev] [GRASS GIS] #3402: g.gui.gmodeler: trying to add command pushes CPU to 100% and provokes freeze
freeze
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.2.2
Component: wxGUI | Version: svn-trunk
Keywords: gmodeler freeze | CPU: Unspecified
Platform: Unspecified |
Trying to add a module call ("Add command") to the modeler leads to 100%
CPU usage and a freeze of the modeler, before the module addition window
content is visible.
I can add data and loops and I can load an existing model and access the
module dialogs, but I cannot add a new module call.
I've tried with trunk, release72, 7.2.1 and release70, all cause the same
problem, so I imagine that it probably has to do with some changes in
relevant external libraries, not in the gmodeler code itself, but I don't
know how to debug this.
I'm on Debian testing, so python-wx 3.0.2.0 and python 2.7.
Can anyone confirm this issue ? It makes the modeler absolutely useless to
me, so I classify this as major, although it only concerns this particular
module.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402&gt;
freeze
Resolution: | Keywords: gmodeler freeze
Comment (by annakrat):
It seems to work on Ubuntu. Do you use GTK3?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:1&gt;
freeze
Comment (by mlennert):
Replying to [comment:1 annakrat]:
I have both 2 and 3 installed on my machine:
libgtk-3-0:amd64 3.22.18-1
libgtk2.0-0:amd64 2.24.31-2
But the wx packages are for gtk 3 and python-wx depends on those:
dpkg -s python-wxgtk3.0
Package: python-wxgtk3.0
Version: 3.0.2.0+dfsg-4
Provides: python2.7-wxgtk3.0
Depends: python-wxversion, python (<< 2.8), python (>= 2.7~), python:any
(<< 2.8), python:any (>= 2.7.5-5~), libc6 (>= 2.14), libgcc1 (>= 1:3.0),
libstdc++6 (>= 5.2), libwxbase3.0-0v5 (>= 3.0.2+dfsg), libwxgtk3.0-0v5 (>=
3.0.2+dfsg)
python-wxgtk2.8 is not available in Debian testing anymore.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:2&gt;
freeze
Replying to [comment:2 mlennert]:
3.0.2+dfsg)
Actually, if I'm not completely mistaken, it's been gtk3 for a while. Do
you think gtk3 is the problem, or is it the minimum version necessary ?
Anything I could do to debug this ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:3&gt;
freeze
what does this give you?
   import wx
   wx.version()
I have '3.0.2.0 gtk2 (classic)'. I just want to make sure it's GTK3, the
'3' in your packages might refer to wxpython 3, not gtk 3.
You can test example OGL in wxpython demo, I suspect there could be a
problem related to this. If the problem is in the dialog, you could try to
remove certain widgets and see if the problem persists. I see it creates a
long list of modules in the wx.Choice widget, maybe that could an issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:4&gt;
freeze
Replying to [comment:4 annakrat]:
> import wx
> wx.version()
Once again (as always :wink: ) you were right:
>>> import wx
>>> wx.version()
And looking better than before, I see that the dependency chain of
packages is:
python-wxgtk3.0 -> libwxgtk3.0-0v5 -> libgtk2.0-0
So, definitely gtk2...
> I suspect there could be a problem related to this. If the problem is in
the dialog, you could try to remove certain widgets and see if the problem
persists.
> I see it creates a long list of modules in the wx.Choice widget, maybe
Commenting out the SearchModuleWidget seems to do the trick:
Index: gui/wxpython/gmodeler/dialogs.py
--- gui/wxpython/gmodeler/dialogs.py (révision 71421)
+++ gui/wxpython/gmodeler/dialogs.py (copie de travail)
@@ -201,11 +201,11 @@
          self.cmd_prompt.promptRunCmd.connect(self.OnCommand)
          self.cmd_prompt.commandSelected.connect(
              lambda command: self.label.SetValue(command))
- self.search = SearchModuleWidget(parent=self.panel,
+ '''self.search = SearchModuleWidget(parent=self.panel,
                                           model=menuModel.GetModel(),
                                           showTip=True)
          self.search.moduleSelected.connect(
- lambda name: self.cmd_prompt.SetTextAndFocus(name + ' '))
+ lambda name: self.cmd_prompt.SetTextAndFocus(name + ' '))'''
          wx.CallAfter(self.cmd_prompt.SetFocus)
          self.label = wx.TextCtrl(parent=self.panel, id=wx.ID_ANY)
@@ -249,8 +249,8 @@
          btnSizer.Realize()
          mainSizer = wx.BoxSizer(wx.VERTICAL)
- mainSizer.Add(self.search, proportion=0,
- flag=wx.EXPAND | wx.ALL, border=3)
+ '''mainSizer.Add(self.search, proportion=0,
+ flag=wx.EXPAND | wx.ALL, border=3)'''
          mainSizer.Add(cmdSizer, proportion=1,
                        flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.TOP,
border=3)
          mainSizer.Add(labelSizer, proportion=1,
I now get a functioning window and when I start entering a module name, I
get the incremental search, can select a module and add it. Will need to
test some more.
Trying to find and test SearchModuleWidget elsewhere in the GUI, I
stumbled upon another encoding issue: #3405. Could this maybe be linked ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:5&gt;
freeze
Replying to [comment:5 mlennert]:
> showTip=True)
> @@ -249,8 +249,8 @@
> btnSizer.Realize()
border=3)
I get the incremental search, can select a module and add it. Will need to
test some more.
However: I can only get one module onto the modeler canvas that way.
Afterwards, when I click on the button to add a module again, nothing
happens at all.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:6&gt;
freeze
Comment (by neteler):
Just FYI: I have made a test on my Fedora 26 box, no CPU issue here (which
I do remember from older wxpython versions, see trac and Fedora's
bugzilla). My current version which seems to work fine:
Python 2.7.13 (default, Jun 26 2017, 10:20:05)
[GCC 7.1.1 20170622 (Red Hat 7.1.1-3)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
import wx
wx.version()
3.0.2.0 gtk3 (classic)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:7&gt;
freeze
Replying to [comment:6 mlennert]:
> > showTip=True)
> > @@ -249,8 +249,8 @@
> > btnSizer.Realize()
border=3)
name, I get the incremental search, can select a module and add it. Will
need to test some more.
happens at all.
This was because of the attempt to reset the non-existant search.
However, I think I found the culprit: the tooltip ! Disabling it makes the
widget work again:
--- gui/wxpython/gmodeler/dialogs.py (révision 71430)
@@ -203,7 +203,7 @@
- showTip=True)
+ showTip=False)
Could it be that there's some encoding needed here ? This said, I have the
same error even if I set all locale settings to 'C'.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:8&gt;
freeze
Replying to [comment:8 mlennert]:
the widget work again:
> @@ -203,7 +203,7 @@
> - showTip=True)
> + showTip=False)
Just to confirm, I tried add showTip=True to the call to the same widget
in gui/wxpython/gui_core/menu.py and it creates the same kind of issue,
only that now the entire GUI freezes as soon as I call g.gui...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:9&gt;
freeze
Could someone for whom this works tell me what the tooltip actually says ?
Or where in the code I can see the content of the tooltip ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:10&gt;
freeze
It takes short description of the module and display is using
StaticWrapText which is defined in widgets.py. I suspect that widget is
the problem, it runs into some infinite loop, could you test, where
exactly is it stuck?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:11&gt;
freeze
Try this if it helps:
Index: gui_core/widgets.py
--- gui_core/widgets.py (revision 71422)
+++ gui_core/widgets.py (working copy)
@@ -1087,7 +1087,7 @@
          self._search.Bind(wx.EVT_TEXT_ENTER, self.OnEnter)
          if self._showTip:
- self._searchTip = StaticWrapText(parent=self, id=wx.ID_ANY,
+ self._searchTip = wx.StaticText(parent=self, id=wx.ID_ANY,
                                               size=(-1, 35))
          if self._showChoice:
@@ -1160,6 +1160,7 @@
          label = _("%d modules match") % len(commands)
          if self._showTip:
              self._searchTip.SetLabel(label)
+ self._searchTip.Wrap(self.GetSize()[0])
          self.showNotification.emit(message=label)
@@ -1193,6 +1194,7 @@
              for module in self._results:
                  if cmd == module.data['command']:
                      self._searchTip.SetLabel(module.data['description'])
                      break
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:12&gt;
freeze
Replying to [comment:12 annakrat]:
> if self._showTip:
> size=(-1, 35))
> if self._showTip:
> break
It does ! Everything seems to work fine with this patch applied.
Thanks, once again, Anna !
How much risk we break something in applying this, including to release72
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:13&gt;
freeze
This is safe, please apply it. But the mystery is that this widget is in
other places, like in every module dialog.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:14&gt;
freeze
Replying to [comment:14 annakrat]:
All the other examples of usages I've found define a label parameter in
the call to the widget. The call in SearchModuleWidget seems to be the
only one that doesn't.
And if I add a label parameter to the call, such as:
Index: gui/wxpython/gui_core/widgets.py
--- gui/wxpython/gui_core/widgets.py (révision 71437)
+++ gui/wxpython/gui_core/widgets.py (copie de travail)
@@ -1088,7 +1088,7 @@
          if self._showTip:
- size=(-1, 35))
+ label="Choose a module", size=(-1,
35))
              self._searchChoice = wx.Choice(parent=self, id=wx.ID_ANY)
the modeler runs perfectly again.
So, before I apply your patch, I'd rather you tell me whether is it better
to apply your patch, my patch, here, in order to be able to keep using
StaticWrapText, or would it be better to find a solution in StaticWrapText
which allows calling it with an empty string ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:15&gt;
freeze
To be complete, my patch has to be
          if self._showTip:
- size=(-1, 35))
35))
@@ -1199,7 +1199,7 @@
          """Reset widget"""
          self._search.SetValue('')
          if self._showTip:
- self._searchTip.SetLabel('')
+ self._searchTip.SetLabel('Choose a module')
  class ManageSettingsWidget(wx.Panel):
Otherwise, you cannot launch the widget a second time...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:16&gt;
freeze
That sounds good, I would apply your patch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:17&gt;
freeze
      Type: defect | Status: closed
Resolution: fixed | Keywords: gmodeler freeze
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:17 annakrat]:
Done in r71439 and r71440.
Closing this for now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:18&gt;
