#3405: encoding issue when launching modules
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: g.search.modules encoding
Comment (by mlennert):
Replying to [comment:5 neteler]:
> Replying to [comment:4 mlennert]:
> > (forms.py:26034): Gtk-WARNING **: Unable to locate theme engine in
module_path: "adwaita",
> Probably you are lacking the adwaita-gtk2-theme package? Here the resp.
Fedora RPM:
Thanks for the hint. In Debian, it's the gnome-themes-standard package.
Installing that gets rid of the Gtk-WARNINGs, but not of the bug trying to
run the modules.
But I'm getting closer. In lib/python/script/utils.py we have the function
encode, with the following code:
if isinstance(string, bytes):
return string
if isinstance(string, unicode):
enc = _get_encoding()
return string.encode(enc)
return bytes(string)
On the work computer the string gets recognized as unicode and therefore
the code in the second if is run. On the home computer, the string is not
recognized as unicode and the last line is run and causes the error.
However, if I modify the code as such:
print type(string)
print "isinstance bytes"
return string
print "isinstance unicode"
print "isinstance none"
the output I get is
> v.to.rast --ui
<type 'str'>
isinstance bytes
<type 'str'>
isinstance bytes
<type 'unicode'> <==================
isinstance none <==================
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/gui/wxpython/gui_core/forms.py", line 2995, in <module>
task.get_cmd(ignoreErrors=True, ignoreRequired=True))
gnu/etc/python/grass/script/task.py", line 248, in get_cmd
errList = self.get_cmd_error()
gnu/etc/python/grass/script/task.py", line 208, in get_cmd_error
{'name': p['name'], 'desc': encode(desc)})
gnu/etc/python/grass/script/utils.py", line 221, in encode
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 36: ordinal not in range(128)
In other words, it is recognized as type unicode, but isinstance(string,
unicode) returns false...
Actually, when type is 'str' it is recognized as unicode:
print type(string)
print isinstance(string, unicode)
gives
<type 'str'>
True
<type 'str'>
True
<type 'unicode'>
False
Any hints explaining why this is happening on one machine, but not the
other ? Python versions are identical (Python 2.7.13).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3405#comment:6>
