#3408: r.tileset fails on windows due to permissions error
Reporter: spawley | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: MSWindows 8 |
The GRASS module r.tileset doesn't appear to function on windows, but
works fine on linux:
r.tileset sourceproj="+proj=tmerc +lat_0=0 +lon_0=-115 +k=0.9992
+x_0=500000 +y_0=0 +no_defs +a=6378137 +rf=298.257222101
+towgs84=0.000,0.000,0.000 +to_meter=1"
File
"C:\OSGEO4~1\apps\grass\grass-7.3.svn/scripts/m.proj.py",
line 308, in <module>
main()
File
line 243, in main
inf = file(infile)
IOError: [Errno 13] Permission denied:
'c:\\users\\cb2dd\\appdata\\local\\temp\\grass7-10432\\tmpovmbzm'
ERROR: cs2cs failed
While r.tileset calls on m.proj, the latter seems to work just fine on
windows:
m.proj -i input=D:\grassdata\alberta_utm12\PERMANENT\.tmp/unknown\13204.1
493843.98|6261734.98|0.00
The issue appears to be related to a problem with permissions to the
temporary file that is passed onto cs2cs.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3408>
