#3411: testsuite: encoding error
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Tests | Version: svn-releasebranch72
Keywords: testsuite encoding | CPU: Unspecified
Platform: Unspecified |
Whenever a test fails in the testsuite, and the LANGUAGE is fr_BE, I get
the following error message
File "test_r_mapcalc.py", line 99, in test_seed_required
self.assertModuleFail('r.mapcalc', expression='rand_x = rand(1, 200)')
File "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/etc/python/grass/gunittest/case.py", line 1180, in assertModuleFail
module.run()
gnu/etc/python/grass/pygrass/modules/interface/module.py", line 769, in
run
self.wait()
gnu/etc/python/grass/pygrass/modules/interface/module.py", line 790, in
wait
module=self.name, errors=stderr)
gnu/etc/python/grass/exceptions/__init__.py", line 71, in __init__
msg += _(". See the following errors:\n%s") % errors
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 37:
ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3411>
