[GRASS-dev] [GRASS GIS] #3418: "Launch Script (*.sh)" doesn't work on Windows
Reporter: kking009 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Default | Version: 7.2.2
Keywords: shell script windows | CPU: Unspecified
Platform: MSWindows 7 |
Grass dispatches the *.sh file to windows, but obviously windows is not
able to handle the bash script.
Applies to all V7.X Versions. On V6.X that was working!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418&gt;
Resolution: | Keywords: shell script windows
       CPU: Unspecified | Platform: MSWindows 7
Comment (by hellik):
Replying to [ticket:3418 kking009]:
I may note that it may be a won't fix.shell scripts aren't cross platform
compatible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418#comment:1&gt;
Comment (by kking009):
On V6.X Grass-Shell-Script were working Cross-Platform! I suppose Grass
were handling them and they weren't dispatched to the OS.
If I copy/execute line by line my script to the Grass-Comamnd-Console,
Grass is able to "handle" my scripts.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418#comment:2&gt;
Replying to [comment:2 kking009]:
I mean it more generally,shell scripts aren't working on all operating
systems out of the box, unless you bundle extra bins with the software
(e.g. msys in winGRASS).
IIRC There is a GRASS_SHELL variable to set (have a look in manual and
wiki), but it's not really maintained anymore to have shell script support
in winGRASS 7, as python is all around on the most is.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418#comment:3&gt;
If you want simpy to execute some GRASS modules in a script, just put the
module commands in a batch file in the following structure (I've added
some notes in the wiki): e.g. myworkflow.bat
Rem set region to a raster
call g.region raster=yourraster
Rem calculate slope
call r.slope.aspect raste=yourraster slope=yourslope
Etc
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418#comment:4&gt;
Replying to [comment:3 hellik]:
Grass were handling them and they weren't dispatched to the OS.
in the [https://grass.osgeo.org/grass73/manuals/variables.html manual]:
GRASS_SH
     [shell scripts on Windows]
     path to bourne shell interpreter used to run shell scripts.
this variable can be set in the winGRASS startup batch file by e.g.
set GRASS_SH="C:\OSGeo4W64\apps\msys\bin\sh.exe"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418#comment:5&gt;
Replying to [comment:4 hellik]:
the module commands in a batch file in the following structure (I've added
> Rem calculate slope
> Etc
for the record the wiki link:
https://grasswiki.osgeo.org/wiki/GRASS_and_bat-files_in_windows_console
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418#comment:6&gt;
I wasn't aware I can execute batch files from the "Grass Startup Console".
They work perfectly!
With the following command it is even possible to run batch files without
starting up Grass:
"%ProgramFiles%\QGIS 2.18\bin\Grass72.bat" --exec MyScript.bat
D:/myGrassData/MyLoc/MyMapset
Nice! For me its fine to close the issue..
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418#comment:7&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: shell script windows
Changes (by martinl):
* status: new => closed
* resolution: => worksforme
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418#comment:8&gt;
Replying to [comment:7 kking009]:
Console". They work perfectly!
without starting up Grass:
I've expanded the wiki with your example:
please improve the wiki entry with your experience. thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3418#comment:9&gt;
