[GRASS-dev] [GRASS GIS] #343: standardize DEG2RAD() etc
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: task | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
in the source now there is
misc/m.cogo/main.c:#define DEG2RAD(a) ((a) * M_PI / 180.0)
raster/r.param.scale/param.h: #define DEG2RAD 0.017453293
raster/wildfire/r.ros/spot_dist.c:#define DEG2RAD 0.017453292
raster/r.flow/r.flow.h:#define DEG2RAD 0.0174532925199432958
it would be good to standardize these in gis.h just following the
M_PI section.
i.e. add these from m.cogo:
#define RAD2DEG(a) ((a) * 180.0 / M_PI)
#define DMS2DD(d,m,s) ((d) + ((m) / 60.0) + ((s) / 3600.0))
  - DMS2DD bug: if deg is negative (45:30S) -> -45 + .5 = -44.5
... or do the macros have to be in the same source file to be kept
efficient?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/343&gt;
Resolution: | Keywords:
  Platform: All | Cpu: All
Comment (by hamish):
Replying to [ticket:343 hamish]:
nope, out->n_s is stored separately from out->lat in m.cogo.
This is easy to forget, so dangerous to put in gis.h in hindsight.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/343#comment:1&gt;
