There is some confusion concerning this message:
main.c:
/* TODO: threshold might be recalculated with optional geodesic
support to meters */
if (G_projection() == PROJECTION_LL)
G_important_message(_("Note: In latitude-longitude coordinate
system specify threshold in degree unit"));
while the documentation reads:
grep meter v.clean.html
case, also the threshold parameter requires several values to be listed
Threshold must always be in square meters, also for latitude-longitude
locations or locations with units other than meters.
Should the G_important_message() be removed from main.c?
#3430: v.clean threshold in lat-long: metric or not?
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Vector | Version: 7.2.2
Resolution: | Keywords: v.clean
Comment (by mlennert):
Replying to [ticket:3430 neteler]:
> From:
> https://gis.stackexchange.com/questions/258089/v-clean-with-rmarea-and-
lat-long-projection
> main.c:
dx = XPnts[pointb].x - XPnts[point].x;
dy = XPnts[pointb].y - XPnts[point].y;
dist2 = dx * dx + dy * dy;
if (dist2 > thresh2) /* outside threshold */
continue;
So while area calculations might use meters (i.e. the rmarea function
mentioned in the SE message), I'm not sure this is the case for snapping
distances... I think this needs very careful review before deciding what
to do.
Comment (by mmetz):
Replying to [comment:1 mlennert]:
> Looking through the code, I actually have the feeling that the
documentation is wrong, at least for some of v.clean's functionalities.
to do.
I suggest to remove the message, because the message does not distinguish
between the different cleaning tools. For tool=rmarea, the threshold must
always be in square meters as stated in the manual. Otherwise, I'm pretty
sure that the threshold is map units, also for latlon.
Comment (by mmetz):
Replying to [comment:2 mmetz]:
to do.
distinguish between the different cleaning tools. For tool=rmarea, the
threshold must always be in square meters as stated in the manual.
Otherwise, I'm pretty sure that the threshold is map units, also for
latlon.
According to https://gis.stackexchange.com/questions/258089/v-clean-with-
rmarea-and-lat-long-projection there is another issue with v.clean
tool=rmarea because it might remove areas that should not be removed. A
test dataset would be helpful.
