#3433: i.zc: unable to handle large maps as everything is done in memory
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.4.0
Component: Imagery | Version: svn-trunk
Keywords: i.zc large files | CPU: Unspecified
Platform: Unspecified |
i.zc fails already in the data initialization stage when trying to analyze
a large map (227,537,282 cells in the region):
i.zc pan out=zctmp width=9 thresh=1
Power 2 values : 16384 rows 32768 columns
Initializing data...
Killed
IIUC, this comes from the fact that everything is loaded into memory,
starting with just the initialization of vectors at the beginning which is
where it fails:
/* get the rows and columns in the current window */
or = Rast_window_rows();
oc = Rast_window_cols();
rows = G_math_max_pow2((long)or);
cols = G_math_max_pow2((long)oc);
size = (rows > cols) ? rows : cols;
totsize = size * size;
G_message(_("Power 2 values : %d rows %d columns"), rows, cols);
/* Allocate appropriate memory for the structure containing
the real and complex components of the FFT. DATA[0] will
contain the real, and DATA[1] the complex component.
data[0] = (double *)G_malloc(totsize * sizeof(double));
data[1] = (double *)G_malloc(totsize * sizeof(double));
/* Initialize real & complex components to zero */
G_message(_("Initializing data..."));
for (i = 0; i < (totsize); i++) {
*(data[0] + i) = 0.0;
*(data[1] + i) = 0.0;
Further on, the module calls functions such as
[https://trac.osgeo.org/grass/browser/grass/trunk/lib/gmath/del2g.c#L46
del2g()] and
[https://trac.osgeo.org/grass/browser/grass/trunk/lib/gmath/findzc.c#L56
G_math_findzc] which use these data structures.
I have no idea what it would entail to rewrite this so as to be able to
deal with larger maps.
At this stage I'm classifying this as an enhancement request as the module
works as such, but I consider that GRASS GIS should not bail out on larger
maps, so am close to considering this as a bug...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3433>
