[GRASS-dev] [GRASS GIS] #3435: r.terraflow tool memory error
Reporter: jess42 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.2.2
Keywords: | CPU: x86-64
Platform: All |
When using 7.2.1 I tried to run the r.terraflow tool I received this
message:
r.terraflow elevation=waitunaDEM@PERMANENT filled=fill direction=flowdir
swatershed=swatershed accumulation=accum tci=tciwaituna
This application has requested the Runtime to terminate it
in an unusual way.
Please contact the application's support team for more
information.
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
STREAM temporary files in C:\Users\jessi\Documents\grassdata
\Waituna\PERMANENT\.tmp/unknown\17040.0 (THESE INTERMEDIATE
STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION
OF THE PROGRAM. TO SAVE SPACE PLEASE DELETE THESE FILES
MANUALLY!)
total elements=1, nodata elements=1
largest temporary files:
FILL: 56 [1 elements, 56B each]
FLOW: 0 [0 elements, 80B each]
Will need at least 112 space available in
C:\Users\jessi\Documents\grassdata\Waituna\PERMANENT\.tmp/unknown\17040.0
Assertion failed!
Program: C:\PROGRA~1\QGIS2~1.18\apps\grass\grass-7.2.1\bin\r
.terraflow.exe
File: 3scan.h, Line 79
Expression: ae == AMI_ERROR_NO_ERROR
(Thu Nov 09 08:45:31 2017) Command finished (7 sec)
When using 7.2.2 I tried to run the r.terraflow tool I received this
message:
(Mon Nov 06 16:32:04 2017)
r.terraflow elevation=waitunaDEM@PERMANENT filled=filled direction=flowdir
in an unusual way.
information.
(Mon Nov 06 16:32:33 2017) Command finished (29 sec)
I have uninstalled and reinstalled the latest version of the software but
I still cannot get this tool to work. 7.2.1 and 7.2.2 were tested on two
different computers that have a large amount of space and RAM.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3435&gt;
Component: Raster | Version: 7.2.2
Resolution: | Keywords: r.terraflow
       CPU: x86-64 | Platform: All
Changes (by martinl):
* keywords: => r.terraflow
* component: Default => Raster
Old description:
message:
in an unusual way.
information.
MANUALLY!)
Assertion failed!
.terraflow.exe
message:
direction=flowdir swatershed=swatershed accumulation=accum tci=tci
in an unusual way.
information.
New description:
message:
in an unusual way.
information.
MANUALLY!)
Assertion failed!
.terraflow.exe
message:
in an unusual way.
information.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3435#comment:1&gt;
       CPU: x86-64 | Platform: MSWindows 8
* platform: All => MSWindows 8
Ticket URL: <https://trac.osgeo.org/grass/ticket/3435#comment:2&gt;
  Priority: normal | Milestone: 7.4.5
Changes (by neteler):
* milestone: 7.2.4 => 7.4.5
Comment:
Did the problem persist? If yes, how many pixels did you try to process?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3435#comment:4&gt;
