[GRASS-dev] [GRASS GIS] #3438: v.buffer silently ignores options depending on buffering alhorithm in use
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Keywords: v.buffer, GEOS | CPU: Unspecified
Platform: Unspecified |
At the moment user gets no warning if some of his input parameters (i.e.
minordistance, angle) are ignored due to use of GEOS instead of native
buffering algorithm. v.buffer should fail with a fatal error if user has
provided unsupported input parameters.
Current approach of setting environmental variable to switch between GEOS
and native algorithms is also suboptimal, as setting env on GNU/Linux is
easy and common, while setting on Windows is uncommon thus hard. A flag
would be better approach.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3438&gt;
Resolution: | Keywords: v.buffer, GEOS
Comment (by marisn):
"tolerance" parameter also works only with the native algorithm.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3438#comment:1&gt;
Comment (by mmetz):
Replying to [ticket:3438 marisn]:
v.buffer prints now (trunk r71724) warnings if options are used that apply
only to the native, deprecated algorithm. The manual is updated
accordingly.
GEOS and native algorithms is also suboptimal, as setting env on GNU/Linux
is easy and common, while setting on Windows is uncommon thus hard. A flag
This is by purpose to make it difficult to use the buggy native algorithm.
The mechanism with an environmental variable exists only in case someone
wants to fix and test the native algorithm.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3438#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.buffer, GEOS
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Seems to be solved, feel free to reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3438#comment:3&gt;
